3 members (Gdads51, JoergK., 1 invisible), 91 guests, and 3 robots.
Topics128,181
Posts1,057,150
Members48,464
Page 3 of 3 1 2 3
T-Doug #1508573 07/09/2023 11:57 PM
No. I couldn’t rotate it before. I put in gear and used the starter to move the carrier so I could get to the bolt to remove pin.
1954 Chevy 3100
One problem solved doesn’t seem to shorten the list
Montgomery, AL
In Project Journals
T-Doug #1508823 07/11/2023 9:59 PM
Progress made today. Got everything but the spider gear back into the pumpkin. Ring gear was still locked so on to transmission. Pulled the top off and Neither fork was where it should be. Cleaned up the gasket flange then dry bolted the lid back down. Put in neutral and voila the ring gear turns easy as pie.
The tranny was really sludged up. Cleaned the fork slides and lubed them. I would have to guess the fluid hasn’t been changed it a while
What is a good oil to use in the transmission
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1508868 07/12/2023 11:59 AM
Been a long time since I played with spider gears so I'll leave that to the more experienced.
Remind us again what transmission you have?
1949/50 3600 Project
Follow in Project Journals
T-Doug #1508883 07/12/2023 1:47 PM
Another step closer to first drive. Got the spider gears in. It was easy once I figured out the secret. Took about 30 minutes playing with them when one feel into the gears and rotated right into place. You have to do both at the same time but once put in place they both rolled into place no problem.
WICruiser I have a four speed. Haven’t researched it yet. Pic two is the cover.
Of course I can’t find a gasket for the pumpkin cover. That and the filler hole nut came off in pieces. It had been put in place with some sort of rubber glue. But it worked I guess. So ordered a gasket and plug.
When I was a young guy working on cars we’d fill up the tranny and rear end until we could feel the oil on a finger stuck through the hole. The repair manual said fill transmission until it overflows out filler hole. Haven’t looked at rear end yet.
Oh. What is the stuff to mark the ring gear with to check and adjust the alignment called.
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1508895 07/12/2023 2:42 PM
A google search says from the number on the transmission cover is for a Muncie SM420.
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1508897 07/12/2023 2:50 PM
The 1951 Maintenance Manual called for using "red lead". Modern gear marking compound (AC Delco # 1052351) is probably easier to find at your FLAPS.
T-Doug #1508909 07/12/2023 4:44 PM
Thanks for that info Bill
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1508930 07/12/2023 6:39 PM
What Bill said.
Although that reminds me of the time when I was back in high school and my Dad's plumbing truck (a '51 GMC) needed rear end work, and Greasy Bob, the local mechanic used the pipe dope that was in the truck to check the gear pattern. So if you happen to have some of that, it would work too.
T-Doug #1509009 07/13/2023 12:17 PM
As for lube in the transmission use 80w-90 gear oil.
T-Doug #1509049 07/13/2023 6:02 PM
"White lead" is lead carbonate powder in a linseed oil carrier. It's easier to see than lead oxide which is used to make "red lead". It was once used to make white paint before the tree huggers got their frilly undies in a wad about anything containing lead. Artists' supply stores sell a modern equivalent pigment that's supposedly lead free. Prussian blue is a grease based dark blue dye that machinists use to check the fit of parts with, and it hasn't been banned- - - -yet. A 2 ounce tube of Prussian Blue is probably a lifetime supply for fitting rear end gears.
"Any of the above" can be used to check tooth contact patterns. Unless a set of used gears had the tooth contact checked and photographed before they were removed from their original housing, the chances of getting a noise-free installation into a different housing are "slim" and "none".
T-Doug #1509538 07/17/2023 5:54 PM
I have a tube of ACDelco Gear Marking Compound in my hand this morning.. I'm working my shop today but tomorrow we are going to give the gear marking a try.. smile
1954 Chevy 3100
Montgomery, AL
In Project Journals
Page 3 of 3 1 2 3
