Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 49 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#15093 05/27/2003 3:28 AM
As some of you may know, I am currently preparing to pull the 305 V6 out of my '62. I removed everything that attaches to the engine, including the hydraulic clutch slave cylinder. But, i looked around, and no ground strap between the block and the frame! I know an engine wont run worth beans or wont run at all without it. Where would this strap connect to if I get a new one? Is there a specific place on the block that it should be bolted to? If it is still attached to the engine and frame, was it in a place that wasnt easily visible? If this was causing my truck to run poorly, then I am pulling the engine for the wrong reasons. Actually, I want to rebuild it anyway, so its not like I dont have a cause. Anyway, if anyone can help, it would be appreciated.
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht-
Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
Starter motor bolt to frame.
They have a way of finding ground without it but don't start as well
I have seen them bolted from the bell housing to the frame. I have also seen straps go from the bell housing to the firewall. The reason for this is the rubber mounts for the body. I have both of
these on my 1992 Suburban which would be more sensitve to poor grounds. grin
