3 members (BC59, cmayna, Peggy M), 144 guests, and 2 robots.
Topics128,095
Posts1,056,475
Members48,444
#1509432 07/16/2023 8:00 PM
]I bought a 1949 3100 truck not sure what engine is in it.
Engine Serial #F0423P
Engine Cast #3789716 Also says "con D180
Head # 3836843
Should be a 292.
"F" Flint Michigan plant
D180 April 18, 1970 ?
Someone will come along and confirm this?
Are you sure on head number? Is the "3" 843 an "8"?
If it's "848" that is a 235 head. If the valve cover is off what date code is the head? Letter followed by numbers like D180
Is your fuel pump mid engine and not towards the front? I believethat is how the 292's are..
If the engine is a 292 I don't think a 235 head will run on it? Experts will be by to confirm.
Does the engine run??
1950 Chevy 3100
Thanks for the help after closer look the head number on the 3 in 843 is an 8
B Online: Content
848 Is 235 head.
I'm reading block as being cast April 8, 1962.
Not intending to offended anyone but many clues it not a 292, 6 volt starter, side cover, threaded vacuum line connection to dist., etc.
No captain's bars visible in view near starter as a 261 would have.
My 2 cents: 1962 235
Is the fan centered with the radiator or does it sit high?
If it is above center it won't cool well, however one of are fine members, pre 68 dave makes a adapter to solve that issue.
BC
p.s.things correct in this post: block cast looks like April 18, 1962, also a Jerry pointed out, fan will sit too low.
So hot here today I can't tell up from down!
BC
1960 C60 pasture art
Right now engine not running bought the truck was told it ran 5 years ago.
BC,
How did you get April 8, 1962?
And thank you!
The engine block 3789716 ?
1950 Chevy 3100
Here's the way I read your numbers...
Engine Serial #F0423 B not P. The "B" was used to ID passenger car 235 with Powerglide transmission.
Engine Cast Date Code D 13 2, not 0 making the cast date April 13, 1962.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
A 1962 235 engine in a 1951 truck will have the fan sitting too low on the radiator, not too high. Dave's adapter plate allows the 216 and early 235 water pump to be used on the later model engines (1955-62) and position the fan correctly. The mid-year change of body styles in the 1955 trucks, and a similar shape change in the 55-up passenger car front end sheet metal required a relocation of the water pump.
Perfect!
1950 Chevy 3100
thanks for the help the fuel pump is towards the front and fan is centered.
They nailed it. 235 with the "good" head..
Great engine. I have a 1957 235 with the "848" head.
Todd
1950 Chevy 3100
