0 members (), 329 guests, and 3 robots.
Topics128,168
Posts1,057,100
Members48,463
I have a 1951 gmc 3/4 ton pickup. It is 6 volt positive ground system. I would like to put a aftermarket raido in but all I can find are 12 volt negative ground.
any suggestions?
Maybe this will help?
I am confused, but that's is normal these days/daze.
Change it to negative ground. Easy process and then get a 12 volt to 6 volt power inverter.
1949 gmc 1-ton
B Online: Content
This should do.
Note their comment about a radio's memory keep alive circuit.
Authorized Pest
Authorized Pest
The Radio Bench Moderator responded here.
Once you get *over there*, we can delete the basically duplicate post.
Hope you can get what you need. Thanks for asking.
wave
~ Peggy M
1949 Chevrolet 3804
"Success comes in 'cans' ..."
Moderated by  truckernix
