2 members (rfs56trk, Guitplayer), 78 guests, and 0 robots.
Topics128,108
Posts1,056,566
Members48,448
I have a 1951 gmc 3/4 ton pickup. It is 6 volt positive ground system. I would like to put a aftermarket raido in but all I can find are 12 volt negative ground.
any suggestions?
Maybe this will help?
I am confused, but that's is normal these days/daze.
Change it to negative ground. Easy process and then get a 12 volt to 6 volt power inverter.
1949 gmc 1-ton
This should do.
Note their comment about a radio's memory keep alive circuit.
Authorized Pest
Authorized Pest
The Radio Bench Moderator responded here.
Once you get *over there*, we can delete the basically duplicate post.
Hope you can get what you need. Thanks for asking.
wave
~ Peggy M
1949 Chevrolet 3804
Moderated by  truckernix
