| | | Forums66 Topics128,154 Posts1,056,856 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | I've tried out Pre 68 Dave's adapter which raises the water pump on my '61 261 to the center of the radiator. Fantastic as most of you already know. It was 90+ today and it idled a long, long time. The water temperature went up to exactly 180 degrees (my thermostat's value) and stayed there.
With the previous stock 261 pump, I would have over heated for sure with maybe a vapor lock. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |  Glad it worked out for you!
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2004 Posts: 41 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 41 |
Let's play together nicely.
| | | | | Joined: Sep 2022 Posts: 6 'Bolter | | 'Bolter Joined: Sep 2022 Posts: 6 | I am curious what about this adapter plate makes the cooling better? Is the the fact you are moving the pump to the middle of the radiator or is the older pump a better design? It seems like the adapter plate would pull the impeller out of the existing 4" hole in the block and make is harder to pump the coolant. | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | The late water pump has far more capacity than the early pump. Its rated output is 14.5 GPM (gallons per minute) per 1,000 pump RPM, 72% higher than the early pump at 8.4 GPM. Using the large late pulley will reduce water circulation significantly. | | | | | Joined: Sep 2022 Posts: 6 'Bolter | | 'Bolter Joined: Sep 2022 Posts: 6 | From my understanding people are replacing the stock 261 pump from their late (55-62) engines with an earlier pump when doing this conversion. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I have used this on my 1960 261 (in my 1954 Chevrolet Suburban).
I highly recommend this adapter it should be listed in a stovebolt hall-of-fame (for appropriate 235s and 261s). | | | | | Joined: Feb 2019 Posts: 4,502 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,502 | I am curious what about this adapter plate makes the cooling better? Is the the fact you are moving the pump to the middle of the radiator or is the older pump a better design? It seems like the adapter plate would pull the impeller out of the existing 4" hole in the block and make is harder to pump the coolant. Pumping more GPM doesn't necessarily mean it will cool better. Slower moving coolant allows more time for engine to transfer more heat to the coolant, then for the coolant to transfer more heat to the radiator. In addition, for those that are replacing their 216 and early 235's with later model 235-261's, the longer pump interferes with the radiator. You can resolved this issue by buying a short shaft water pump made specifically for this mod, shorting the pump yourself, or moving the radiator to the front of the support. None of these mods will center the pump on the radiator causing inefficient cooling. Some 'bolters have done this and attest to no cooling issues, but others have not been as lucky. I have installed this adaptor on a '59 235 in my '52 Chevy 3100 and it works great. My hats off to "Pre '68 Dave".
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | I bought the short shaft water pump a few years ago when I didn’t know any better. It works for me, although the truck will start to creep up to 200 ish when idling for long periods on a very hot day.
I have not put it to an extreme test, but I suspect that I might have trouble in a traffic jam.
When the time is right (other major engine work or swap), I will do the adapter plate with the earlier pump.
1951 3100
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Pumping more GPM doesn't necessarily mean it will cool better
GM thought so | | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | In racing engines they're pumping a barrel a minute through the engine at high RPM. Higher coolant velocity minimizes hot spots.
I'm using the low mount pump and a 16" 6-blade truck fan, the bottom blades of which extend below the radiator. I had to drop the radiator in the mounting hoop several inches so the fan would clear the lower radiator hose outlet. If I was a good sheetmetal man I'd make a shroud to fit. Instead I added a pusher fan in front of the radiator with a 205 degree-on switch from the Peterbilt dealer and a relay. On a long, hard pull on a hot day it will go over 200 degrees, otherwise runs at 180 per the thermostat. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Feb 2004 Posts: 29,851 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,851 | Everybody is ignoring pulley diameters in this fire hydrant watering contest. The usual suspects are pontificating about theoretical stuff when it's an established fact that the conversion plate works, keeps the engine cool, and avoids having to do a bunch of modifications when using a later model engine in an early chassis designed for the high pump. It's also possible to machine the pressed-on pulley of the early pump and install a 2-sheave pulley for a Furd small block V8 to accommodate non-standard belt routing for power steering, air conditioning, etc. Jerry
| | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | If you run the small pulley high-mount waterpump on a late 235 with it's factory crank pulley you are in danger of making a nice, clean slot in your hood when a fan blade comes off. My next-door neighbor did exactly that to his 51 car.
If I wasn't so far into my current setup I might consider the adapter plate setup. But the current setup works for me, keeps cool, drives the AC compressor, keeps the house battery for the camper charges and doesn't trash belts.
