| | | Forums66 Topics128,014 Posts1,055,332 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 31 Junior Member | | Junior Member Joined: Nov 2006 Posts: 31 | I need to rebuild my e-brake. it is very sloppy in the pins and mechanics. at the moment it does work but most of the movement of the handle is to take out the slop before it grabs. do you have any good ideas, such as welding up the holes and grinding them back out, putting in bigger pins. I could use some advice on this subject. thanks, Jay | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | drum as in rear wheels, or on back of the trans? slop can be in the front area, between there and the brakes, or even in the brakes themselves, and most importantly, different series are different .... what year we talkin?
Bill | | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | The parking brake on my beast is much the same way. The lever is very sloppy and just plain worn out, as is the locking mech. I have the lever & linkage off to pull the engine/trans & plan on fixing it then. I'm thinking I can have the lever bored & fit for a sleeve at the local machine shop to take the side slop out of it, the rest I plan on doing myself. 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I,ve done a lot of clutch linkages & such by building them up with brass weld & filling & grinding them to fit. Works good. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2006 Posts: 31 Junior Member | | Junior Member Joined: Nov 2006 Posts: 31 | it is on the back of the trans. 1951 2 ton | | |
