| | | Forums66 Topics128,110 Posts1,056,255 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 18 Junior Member | | Junior Member Joined: Jan 2007 Posts: 18 | I thought I had a 235 six cylinder in my 1955 2nd seies 6400 truck but while reading the old post on the forum I came across some literature that said there were some 261 engines in the bigger trucks and it listed the block number for the 1955, 261 as 3837012. When I check, that is the number on my block. Also it looks like under the orange paint on the engine it used to ne painted yellow. [img]http://thumb9.webshots.net/t/59/759/7/48/39/2864748390100433169qHIIMn_th.jpg[/img] | | | | | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | check for captains bars at starter,,,261,,,,doc | | | | | Joined: Jan 2007 Posts: 18 Junior Member | | Junior Member Joined: Jan 2007 Posts: 18 | I am working on getting the brakes to work right now. Also have a fuel tank problem but the motor runs very well. A little more work and she'll be road worthy! Thanks for the help. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Not all 261's have the Captains Bars. That casting no., on the passenger side of the block, is the best indicator. I had a engine, I pulled sitting here, that I thought for the longest time, was a 235, but after the previous owner insisted that it was actually a 261, I looked it up on the inliners site, & discovered it was actually a 261. It had no Captains bars, as my other 261 had. | | |
