2 members (Greg_H, 1 invisible),
106
Mod | | | Forums66 Topics128,263 Posts1,058,136 Members48,482 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | I'm trying to decipher the stamped numbers on my rear axle, truck is a 1986 C10. Numbers are G345 and I cannot find this sequence on the decoding chart. | | | | | Joined: Feb 2004 Posts: 29,923 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,923 | How many bolts does the rear cover have, is it oval, round or odd-shaped? Can the ring and pinion carrier assembly be unbolted from the front of the housing? Dana-Spicer axle assemblies like the Type 44 or Type 60 have a roughly triangular-shaped rear cover and the carrier is not removable from the front. Can you post some pictures? Jerry
| | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | It is a GM 8.5" rear diff., 10 bolt. I raised one wheel off the ground and did the count, ended up being a 2.73. Since I use this truck for towing, I pulled those out and put in 3.42 gears. | | |
