4 members (walter74, Greg_H, Guitplayer, RLB), 94 guests, and 2 robots.
Topics128,055
Posts1,055,785
#1507803 07/04/2023 2:45 PM
1954 235 6 volt rebuilt, good compression, rebuilt starter, grounds all check out good, 00 gauge battery cable, new battery. Ive been through old threads and tried all the recommended solutions, nothing yet
what am I missing. turning over to slow to fire.
thanks
Big Bolt Forum Moderator
Is it possible the starter was rebuilt using a 6v armature or field coils? I had someone put wrong field coils in a golf car motor (24v instead of the needed 36v) and it went like gangbusters, so fast it almost bounced the guy out of the seat on the golf course, going the other way would cause your slow turnover.
Mike
Try cranking the engine with a 12V battery, or just use jumper cables from a 12V vrhicle for a short burst to see how the starter reacts. It's not a fix, just a troubleshooting tool. If the engine cranks noticeably faster, PM me for some guidance on doing a "series resistance test". It's a bit too complex to describe on the open forum with a dozen others arguing about how, or if the test should be done.
I just pulled the starter and hooked up to jump pack and it spins super slow and I can stop with my fingers. I’m thinking something went wrong on the rebuild
Who did the the rebuild? if it was a professional service, they need to do it again and pay for the shipping.
1950 Chevrolet 3100 (Ol' Roy)
It was local shop and they did great by me before.
They'll probably make it right then. Clearly something didn't get done right for you to be able to stop the starter gear with your hand.
7
7 Offline
I would try it with a known GOOD battery instead of the jump pac. If it turned the engine over with a battery you should not be able to stop it with your hands.
Just brought starter back to shop. Will let you all know what they find. Appreciate the help
