| | | Forums66 Topics128,054 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2021 Posts: 52 'Bolter | | 'Bolter Joined: May 2021 Posts: 52 | 1954 235 6 volt rebuilt, good compression, rebuilt starter, grounds all check out good, 00 gauge battery cable, new battery. Ive been through old threads and tried all the recommended solutions, nothing yet what am I missing. turning over to slow to fire. thanks | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | Is it possible the starter was rebuilt using a 6v armature or field coils? I had someone put wrong field coils in a golf car motor (24v instead of the needed 36v) and it went like gangbusters, so fast it almost bounced the guy out of the seat on the golf course, going the other way would cause your slow turnover. | | | | | Joined: Feb 2004 Posts: 29,773 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,773 | Try cranking the engine with a 12V battery, or just use jumper cables from a 12V vrhicle for a short burst to see how the starter reacts. It's not a fix, just a troubleshooting tool. If the engine cranks noticeably faster, PM me for some guidance on doing a "series resistance test". It's a bit too complex to describe on the open forum with a dozen others arguing about how, or if the test should be done. Jerry
| | | | | Joined: May 2021 Posts: 52 'Bolter | | 'Bolter Joined: May 2021 Posts: 52 | I just pulled the starter and hooked up to jump pack and it spins super slow and I can stop with my fingers. I’m thinking something went wrong on the rebuild | | | | | Joined: Oct 2021 Posts: 6,762 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,762 | Who did the the rebuild? if it was a professional service, they need to do it again and pay for the shipping.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: May 2021 Posts: 52 'Bolter | | 'Bolter Joined: May 2021 Posts: 52 | It was local shop and they did great by me before. | | | | | Joined: Oct 2021 Posts: 6,762 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,762 | They'll probably make it right then. Clearly something didn't get done right for you to be able to stop the starter gear with your hand.
| | | | | Joined: Feb 2016 Posts: 1,985 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,985 | I would try it with a known GOOD battery instead of the jump pac. If it turned the engine over with a battery you should not be able to stop it with your hands.
| | | | | Joined: May 2021 Posts: 52 'Bolter | | 'Bolter Joined: May 2021 Posts: 52 | Just brought starter back to shop. Will let you all know what they find. Appreciate the help | | |
