0 members (),
77
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#15067 08/05/2003 5:09 PM | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Talking the other day and got on the subject of transmission lubricants for standard trans. Mechanic who has a local shop says Amsoil is used a lot for this and is real thin, like a 10w. Says Nascar is using this thin weight oil in their racecars. Doesn't seem quite right to me and know all the manuals and past experience say use 90w in the trans and rearend. Would like to hear what you are using in this area and your opinions. Bruce
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
#15068 08/05/2003 6:11 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Running 80W-90. Don't forget, Nascar doesn't use production parts, all the gearboxes are built to very tight tolerances. And the newer manual trannies use ATF for lube. Don't try it in one of these old gals unless you are an expert at arranging drip pans under your truck!
Fred 52 3600 69 C-10
#15069 08/05/2003 7:21 PM | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | I can relate to drip pans under the truck.  | | |
#15070 08/06/2003 12:44 PM | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Drip pans! Did I read drip pans. This was the reason I posted this question. Recently rebuilt 3 speed trans came from the builder with the thin oil in it. After a few days I notice oil spots on the driveway. Seems its coming from the clutch assy cover plate. Will be draining the trans and using the heavier stuff this weekend. Hopefully this will stop the mess. Thanks for the info. Bruce
#15071 08/06/2003 2:59 PM | Joined: Mar 2003 Posts: 313 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 313 | Wish I could add some positive information to this, but in talking with an elderly gentlemen who built 35 to 46 GMC's at the factory, he said "Boy, that truck of yours leaked the day that it got built,get over it". Been a real fan of drip pans. | | |
#15072 08/06/2003 5:58 PM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | My manual states to use 50W detergent oil (49 GMC) in the three speed. Don't know what your tranny is but it also states NEVER to use hypoid oil. Ruins the innards!  | | |
#15073 08/07/2003 4:04 PM | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Standard 3 speed trans. No OD, nonsynchro 1st gear. Bruce
#15074 08/07/2003 6:47 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Originally posted by 49 geezer: My manual states to use 50W detergent oil (49 GMC) in the three speed. Don't know what your tranny is but it also states NEVER to use hypoid oil. Ruins the innards! Dang! I just learned something. They must have used babbit bearings, cuz hypoid oil will ruin them.
#15075 08/09/2003 12:02 AM | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | Fred,
Actually, I think there are sulphur compounds in the Hypoid lube that attack the bronze bushings inside the tranny...
At least, this is what I THINK I read on the AACA website....
Have always read SAE 80-90 for the manual truck tranny....and whatever you're putting in the rear end should have an EP rating ("Extreme Pressure") for the hypoid ring & pinion.
The ONLY antique trannys I've ever seen use less than gear lube were the Chrysler semi-autos that used SAE-10 oil.
If some rebuilder tells you "light oil" is okay in your 'Bolt's tranny, ask him if he'll give you a warranty on the tranny which will include free rebuild-replacement for at least 50,000 miles!
Frank McMullen 1941 Chevy dump truck 1949 GMC 100 pick-up 1954 Chevy 3600 pick-up 1955.1 4400 dump truck 1941 De Soto & other MoPars 1928 Model A F**D Special Coupe
#15076 08/09/2003 2:26 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | wbkinsey,
What year transmission do you have (is it GMC or Chevrolet)?
For what it's worth, the USA and Canadian Shop Manuals specify Multi-Purpose SAE 90 lubricant for 1954 standard 3-speed, heavy duty 3-speed, and four speed.
Tim | | |
#15077 08/09/2003 2:14 PM | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | TC: Trans is the standard Chev 3 spd in a 1959 1/2 ton.
Ron: I agree with your statement but we don't get sub-zero temps here in GA
Will be going with the 80w-90 or straight 90w. Bruce
#15078 08/09/2003 6:00 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | 90 weight gear oil and 50 weight engine oil are the same viscosity, the numbers are different to avoid misuse.On the websites of some major lube makers is the warning about using modern GL-5 gear lubes in older gear boxes,additives attacking yellow metals(brass and bronze?) as mentioned above.If the gear box was designed to use motor oil,or a light oil then it should be ok.Spicer used to recomend the use of 50 weight motor oil ,not gear oil in some medium duty truck trannies.Many modern gear boxes use thin ATF as a lube.The NP 3500-4500 series transmissions use a light gear oil.The NP A833 4 spd OD tranny is supposed to use ATF, but Mopar guys say to use a 75-90 gear oil for less noise and longer life. | | |
#15079 08/09/2003 10:54 PM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Looking at my original (read old) 1949 GMC manual on lubrication. Says that the tranny take a "ES" special engine oil. "SAE 50, ordinary gear oils are not satisfactory, detergent dispersant properties, oxidation resistance and anti-foam." Used it in mine. Whined when I got it, still whines but what the hell, at least it's full and lubricated. :p | | |
