4 members (Otto Skorzeny, J Lucas, TexasA&M48Truck, Ed Atkisson), 86 guests, and 6 robots.
Topics128,021
Posts1,055,373
Members48,420
#15067 08/05/2003 5:09 PM
Talking the other day and got on the subject of transmission lubricants for standard trans. Mechanic who has a local shop says Amsoil is used a lot for this and is real thin, like a 10w. Says Nascar is using this thin weight oil in their racecars. Doesn't seem quite right to me and know all the manuals and past experience say use 90w in the trans and rearend. Would like to hear what you are using in this area and your opinions.
Bruce
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
#15068 08/05/2003 6:11 PM
Running 80W-90. Don't forget, Nascar doesn't use production parts, all the gearboxes are built to very tight tolerances. And the newer manual trannies use ATF for lube. Don't try it in one of these old gals unless you are an expert at arranging drip pans under your truck! grin
Fred
52 3600
69 C-10
#15069 08/05/2003 7:21 PM
I can relate to drip pans under the truck. smile
#15070 08/06/2003 12:44 PM
Drip pans! Did I read drip pans. This was the reason I posted this question. Recently rebuilt 3 speed trans came from the builder with the thin oil in it. After a few days I notice oil spots on the driveway. Seems its coming from the clutch assy cover plate. Will be draining the trans and using the heavier stuff this weekend. Hopefully this will stop the mess. Thanks for the info.
Bruce
Bruce
#15071 08/06/2003 2:59 PM
Wish I could add some positive information to this, but in talking with an elderly gentlemen who built 35 to 46 GMC's at the factory, he said "Boy, that truck of yours leaked the day that it got built,get over it". Been a real fan of drip pans.
1936 GMC T-14 1/2-Ton Pickup
#15072 08/06/2003 5:58 PM
My manual states to use 50W detergent oil (49 GMC) in the three speed. Don't know what your tranny is but it also states NEVER to use hypoid oil. Ruins the innards! eek
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
#15073 08/07/2003 4:04 PM
Standard 3 speed trans. No OD, nonsynchro 1st gear.
Bruce
Bruce
#15074 08/07/2003 6:47 PM
Quote
Dang! I just learned something. They must have used babbit bearings, cuz hypoid oil will ruin them.
Fred
52 3600
69 C-10
#15075 08/09/2003 12:02 AM
Fred,
Actually, I think there are sulphur compounds in the Hypoid lube that attack the bronze bushings inside the tranny...
At least, this is what I THINK I read on the AACA website....
Have always read SAE 80-90 for the manual truck tranny....and whatever you're putting in the rear end should have an EP rating ("Extreme Pressure") for the hypoid ring & pinion.
The ONLY antique trannys I've ever seen use less than gear lube were the Chrysler semi-autos that used SAE-10 oil.
If some rebuilder tells you "light oil" is okay in your 'Bolt's tranny, ask him if he'll give you a warranty on the tranny which will include free rebuild-replacement for at least 50,000 miles!
Frank McMullen
1941 Chevy dump truck
1949 GMC 100 pick-up
1954 Chevy 3600 pick-up
1955.1 4400 dump truck
1941 De Soto & other MoPars
1928 Model A F**D Special Coupe
#15076 08/09/2003 2:26 AM
wbkinsey,
What year transmission do you have (is it GMC or Chevrolet)?
For what it's worth, the USA and Canadian Shop Manuals specify Multi-Purpose SAE 90 lubricant for 1954 standard 3-speed, heavy duty 3-speed, and four speed.
Tim
#15077 08/09/2003 2:14 PM
TC: Trans is the standard Chev 3 spd in a 1959 1/2 ton.
Ron: I agree with your statement but we don't get sub-zero temps here in GA
Will be going with the 80w-90 or straight 90w.
Bruce
Bruce
#15078 08/09/2003 6:00 PM
90 weight gear oil and 50 weight engine oil are the same viscosity, the numbers are different to avoid misuse.On the websites of some major lube makers is the warning about using modern GL-5 gear lubes in older gear boxes,additives attacking yellow metals(brass and bronze?) as mentioned above.If the gear box was designed to use motor oil,or a light oil then it should be ok.Spicer used to recomend the use of 50 weight motor oil ,not gear oil in some medium duty truck trannies.Many modern gear boxes use thin ATF as a lube.The NP 3500-4500 series transmissions use a light gear oil.The NP A833 4 spd OD tranny is supposed to use ATF, but Mopar guys say to use a 75-90 gear oil for less noise and longer life.
#15079 08/09/2003 10:54 PM
Looking at my original (read old) 1949 GMC manual on lubrication. Says that the tranny take a "ES" special engine oil. "SAE 50, ordinary gear oils are not satisfactory, detergent dispersant properties, oxidation resistance and anti-foam."
Used it in mine. Whined when I got it, still whines but what the hell, at least it's full and lubricated. :p
