6 members (51sub, JW51, 55shaker, Stovebolt48, Gray_Ghost, 1 invisible), 71 guests, and 0 robots.
Topics128,042
Posts1,055,595
#1507467 07/01/2023 3:54 PM
I did not know if this should go in the "Interior" or "electrical" forum. Has anyone found a source for a 6v dash fan. I am still running 6v and would like to add a dash fan but no one seems to have one available unless you want to pay hundreds for a refurbished original. Is there anyway to convert a 12v fan to 6v? What is required?
I will try the 12v on the 6v power supply to see what happens.
Dave from Northern Kentucky
My 54 3100
dgrinnan #1507468 07/01/2023 4:00 PM
7
7 Offline
Try running the 12-volt fan on 6 volts and see if it throws enough air, if it's a simple brushed 12-volt permanent magnet motor it will run.
dgrinnan #1507476 07/01/2023 5:16 PM
Moderator, Electrical Bay
J Online: Content
I sold one I had a few months ago. I think I had two at one time, although one may have been a 12v. Will look in the attic next time I can.
You can convert 12 to 6v, but it is a real process if you're talking about rewiring the armature. Best to use a 12v to 6v step-down adapter like this one:
https://tinyurl.com/3w9ft2w8
~ Jon
dgrinnan #1507483 07/01/2023 5:44 PM
I have a Trico vacuum fan (soft blades).
I see them on Epay all the time. Yes, prices are high but they are still listed for like 60 bucks on average. As long as you have a vacuum line to hook it into. I spliced my wiper line under the dash with a "Y" and a diverter to use either wiper or fan.
I can tell you it's No A/C but it moves Air, both in summer and winter.
Todd
1950 Chevy 3100
dgrinnan #1507573 07/02/2023 1:29 PM
Thanks Jon, but my truck is 6v and I can only find a 12v fan. I don't need to step 12v down to 6v. I need to go the other way or find a 6v fan.
My 54 3100
dgrinnan #1507574 07/02/2023 1:38 PM
Sometimes the answer is right in front of you. You got me thinking Jon. 12v to 6v. why not 6v to 12v. They are readily available. Problem sovled. I can buy a commonly available 12v fan and add a 6v to 12 tranformer.
My 54 3100
dgrinnan #1507641 07/02/2023 8:36 PM
Transformers do not work on DC voltages, a transformer is an AC only device.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
Mike Burns #1507652 07/02/2023 11:00 PM
I was going to say that, but there are lots of electronic 6-12V converters available. I saw one on Amazon after Dave posted about that for just over $12 that would support light loads and another for twice the amount that would carry a 10A load.
I think you're being a little strict on your definition of "transformer". wink
dgrinnan #1507655 07/02/2023 11:12 PM
I am sure you are right about the ransformer and DC but here is the description of the one I just bought.
6V to 12V Step Up Converter, DROK DC 5V-11V to 12V Boost Converter Voltage Regulator Module 3A 36W Volt Transformer Power Supply for Car Stereo Radio
My 54 3100
dgrinnan #1507680 07/03/2023 3:54 AM
Boost converter is the correct name for that.
The word salad name is just trying to hit all the possible search terms that someone might try when looking for it.
Is 3A going to be enough for your fan?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
klhansen #1507702 07/03/2023 12:27 PM
Sorry, I didn't mean to sound like a smartelec. I just didn't want for you to buy a simple transformer, thinking that it would work for your application.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1947 Indian Chief
1943 Indian 741
dgrinnan #1507722 07/03/2023 7:32 PM
You didn't. I was pointing out that the seller of an electronic component didn't know his own product.
My 54 3100
