| | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2022 Posts: 557 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 557 | Took my 54 3100 (6volt) out for some gas and lunch today... 20 miles one way. Been having hot start troubles, nothing serious, just has to crank over real slow a few revs before catching up. Today after getting gas, the temp gauge was at 210. Finally got it started and it was cooling down as I drove off the lot. Stopped 6 miles later at the truck stop on 95 for lunch. Got back in and stepped on the starter and... nothing. Tried again and... nothing. Tried a third time and it turned over r e a l slow, caught up and started. Came straight home to the shop. Never got it to turn again. Swapped it out with the old stock starter and did fine. Took the switch off and the motor reved just fine with a 12 v jump. The switch contacts were out of line and would not connect. Rebuilt starter less than 4 months old. I'll sent it back and use the old one off of my 216.
~~ Jethro 1954 3100Back to LifeIn the Dity Gallery1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020 | | |
