3 members (Ponchogl, Wheelie, John Dlugos), 93 guests, and 2 robots.
Topics128,128
Posts1,056,358
Members48,441
I need to get a master cylinder rebuild kit for my 1970 C50. it is a duel resivor type with a hydrovac under the cab. can't find any #'s on it and parts stores are having a hard time finding a listing. I am also replacing the lines down from it but it has 2 rubber lines on the frame just down from the master. can't find these any where either. I thought of just making a loop of line after the master to take up shock and eliminating the hoses. what do you think??
1970 C50 dump! saving orphans from the CRUSHER
How many tons is a C50 truck???
Riding in the Passing Lane
Napa catalog shows part # 478 for a kit. 1 1/2" dia. cyl. Part # 36229 for a complete cyl. C50 is considered 1 1/2 tons.
1972 Chevy c10 Cheyenne Super
rust master
try this web site http://www.rockauto.com/
and look up the biggest truck or van of that year and they should show a pic and part number for the master cylinder and Hydro vac alot of those bigger trucks used these same parts common to the one tons and heavy duty 3/4 tons
hope this helps DS
Thanks, Our near by napa store SUCKS! They act as if you are bothering them for a part. Even the owner has a attitude. Thats probably why one of his stores went out of buisness. He had 2 stores at one time. I'll have to find a better napa around here. autozone can't find a application, but I think the kid only knows how to look up honda parts.
Oh ya! what about those hoses after the master cylinder??? they look like the hose that goes out to the wheel but shorter
Wrenchbender, I looked at those napa #'s the kit might be right but the master # looks like it's for a half ton (only 15/16 bore) Mine also has a bolt on cover.
My catalog shows 36229 as 1 1/2 in with a bolt down cap. Illistration # 61. It is an old catalog I keep around for this old stuff. It may have been changed by now. I can get a Carquest number tomorrow when I get to the shop.
Carquest part #,s. M413 for the kit. E57530 for the master cyl.
Thanks wrenchbender. I'll try to give the #'s to a local parts store and see if they can get them,or cross refrance.
