0 members (),
37
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2019 Posts: 80 Jim C. Blue | | Jim C. Blue Joined: Aug 2019 Posts: 80 | There is a problem I've been having for a while with my truck. It is a '53 with a 292 six out of a '66. It has the GM 3-wire alternator, the one with a wire for ignition and two red wires that come together into one. The problem I'm having is keeping a steady voltage. The biggest culprit would be the electric fans. Since the 292 didn't leave enough room for a regular fan, I had to wire up some electric ones. It is a dual fan that I salvaged from a 2000-something Dodge truck. Just wired up directly with a switch on the dash. Whether I have one or both fans connected, turning them on causes a huge drop in voltage, then settles for barely above 12v. When off, it is above 14v. I also noticed it fluctuates a little with the turn signal on.
Am I in desperate need of a different electric fan? Is there a better way to wire it up? Is the internal voltage regulator shot? Can an external regulator be added to an alternator that has an internal one? Or is everything actually just fine?
(Recently tried to add an external regulator, but I was given a Chrysler/Dodge two pin and couldn't figure out how to wire it into the GM alternator wiring.) Alexander's Automotive Assortment- 1953 GMC 9700 3-ton**
- 1978 Plymouth Arrow
- 1980 Jeep J10 Cargo Truck
- 1985 Red Wagon Trailer (for cars)
- 1986 Toyota Tercel Wagon 4wd
**(9700 in Canada or 450 in USA.)
| | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | Have you checked the current output of the alternator? One bad diode will drop the current capacity of the stator to less than one third of its rated capacity, without affecting the alternator's ability to produce normal voltage. I've seen "55 amp" alternators with an open circuited diode in the rectifier bridge produce less than 15 amps max- - - -runs the vehicle OK in the daytime, but slowly discharges the battery with headlights or a heater fan running. Have someone who knows how to use an ammeter check the alternator for max output. Jerry
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You need a larger output alternator. Those fans draw a lot of current.
George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2014 Posts: 4,475 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,475 | You've received two excellent answers, Alex. Please let me add my personal note: First, I'd concentrate more on amperage than voltage. For decades I've told people to think of voltage as the size of your arm and amperage as the strength of your arm. I also have 2 electric fans, HEI ignition and I have a 100 amp alternator...or that is to say it is rated at 100 amp. The HEI ignition uses around 20 amps briefly at startup and after that settles back to around 7 amps. I haven't had the alternator checked for actual maximum output. I expect if it is a true 100 amp unit it will be ~80-90 amps given the pulley ratio I have and the rpm range at which my engine normally runs. One fan is a Spal puller fan (17") and one is a Spal pusher fan (16") which operates only when the A/C is on. The 17" fan is thermostatically controlled so it only runs when needed. When both fans are running I'll lose about 50 amps according to Spal's tech data. While that is happening, anything like the headlights, turn signal lights, etc will be seen as a reduction on my ammeter gauge (in the dash cluster). Hope this is helpful.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Jan 2022 Posts: 2,435 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,435 | Given Alex's comment two red wires that come together into one. there is another thing that MAY help his situation. The T2 (sense) wire, the smaller of these "two red wires that come together", should ideally be connected back in the electrical system under the dash somewhere (that is how GM designed it) instead of to the output lug on the alternator. That way it will sense "system" voltage instead of alternator output voltage. A good place to connect it might be on either terminal of the ammeter or the bat terminal of the ignition switch. This isn't going to SOLVE Alex's problem, but it should make it better than his charging system which is operating as a 1 wire alternator now.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Aug 2019 Posts: 80 Jim C. Blue | | Jim C. Blue Joined: Aug 2019 Posts: 80 | The T2 (sense) wire, the smaller of these "two red wires that come together", should ideally be connected back in the electrical system under the dash somewhere (that is how GM designed it) instead of to the output lug on the alternator. THANK you! I just did that (to the ammeter), and it made a huge difference! Now it goes back above 14v when the fans are turned on. Thank you to everyone for your help.
| | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | Since electrons move at approximately the speed of light (186,000 miles per second)- - - -tell me how connecting a wire in a different position on a vehicle is going to make a measurable difference in how the alternator performs. "Inquiring minds want to know!" LOL! Jerry
| | | | | Joined: Jan 2022 Posts: 2,435 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,435 | tell me how connecting a wire in a different position on a vehicle is going to make a measurable difference in how the alternator performs. "Inquiring minds want to know!" LOL! Jerry Likely poor connections in the electrical system. Drop a quarter volt here, a quarter volt there and eventually they add up. But I didn't feel like explaining how to use a voltmeter to look for small drops at each connection. As I said above "that's how GM did it". They wouldn't have wasted a few cents (in 1972) on 6 feet of wire for a sense line under the dash. And they could have eliminated the T2 connector and just internally connected T2 to the output lug. Wait! They did that at one point. It was called a one wire alternator.
| | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | Since electrons move at approximately the speed of light (186,000 miles per second)- - - -tell me how connecting a wire in a different position on a vehicle is going to make a measurable difference in how the alternator performs. "Inquiring minds want to know!" LOL! Jerry It isn't timing issue, it is a voltage drop issue. Hooked together at rhe alternator, the feedback is tied to the voltage at the alternator, but as you pass through various connections and wires that all have some resistance, the voltage drops a little bit with each one. When you add a high current load, the small resistances suddenly cause a much larger voltage drop. So tying the feedback into the post-drop circuit allows it to manage the overal system voltage better. | | | | | Joined: Jun 2021 Posts: 157 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 157 | Since electrons move at approximately the speed of light (186,000 miles per second)- - - -tell me how connecting a wire in a different position on a vehicle is going to make a measurable difference in how the alternator performs. "Inquiring minds want to know!" LOL! Jerry Here is some interesting read on this http://www.madelectrical.com/electricaltech/remotevoltagesensing.shtml | | | | | Joined: Aug 2005 Posts: 124 6 heaven | | 6 heaven Joined: Aug 2005 Posts: 124 | So,that sense wire should be connected at the same point where the wiring feeds the loads. Maybe the starter stud where the main battery cable comes from the battery? Maybe use this point to feed the loads and the sense voltage? If the sense wire is on the alternator hot stud, maybe feeding some loads from that point would also act like that. | | | | | Joined: Aug 2019 Posts: 80 Jim C. Blue | | Jim C. Blue Joined: Aug 2019 Posts: 80 | You know what else helps? Being more careful with old electrical stuff. First, there was a bare wire to the coil and repeatedly shorting out. Next, the key ignition was loose and hot. Likely because I failed to realize I should have changed it out from 6v to 12v. I fixed those, but I really should plan to replace all old wiring in the future. Alexander's Automotive Assortment- 1953 GMC 9700 3-ton**
| | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | The switch doesn't care what voltage the system runs. However, loose connections are always "hot" connections- - - -looseness produces resistance, and overcoming resistance causes heat. A 6V ignition switch actually has bigger, heavier contacts than a 12V, because it takes twice the current to produce the same wattage as a 12V accessory- - - -"voltage X amperage = Wattage". 6V wiring is always heavier gauge than 12V, also. Jerry
