5 members (2-Ton, stlcardinalsguy, 1955 1 Series, Otto Skorzeny, Oswald), 66 guests, and 5 robots.
Topics128,180
Posts1,057,157
Members48,464
I need a tool to properly seat the rear main oil seal in a GMC 302 engine. I have a trashed crankshaft from a GMC 228 that uses the same bearings. I do not have, nor do I know how to drive an oxy-acetylene torch. Does it make sense to find someone local to lop off the rear bearing portion of the crank to use as a tool? GMC Maintenance Manual shows a picture of a "mandrel" to do the job, but doesn't list specs or a Kent-Moore part number.
Or should I try to find someone with a wood turning lathe to make such a tool?
Aluminum is much easier to work with than steel, and much more durable than wood. Give me a good diameter and width measurement of the seal surface on the crankshaft, and I can whittle one out on the lathe in about an hour. I made a rope seal seating tool for John's 261 from an old piston.
Bill Hanlon That aluminum offer sounds best but your local welding shop could cut it or find a metal chop saw or get a cut-off wheel for your hand grinder.
A large socket rolled over the seal works pretty good. Heres how I assemble Pontiac's, they use a two piece rope seal, I install the one piece of the seal in the block leaving it long, drop in the crank, and use a block of wood to tap the crank down into the seal till the crank hits the bearing. I then remove the crank, pull the seal, install the second piece and repeat. The first piece is installed in the cap and trimmed to length. The second piece is then trimmed, and ready to use. The real key to rope seals is using https://bestgasket.com/rear-main-seals/ brand seals if available for the engine. They are a far better seal then what comes in gasket kits.
Joe H That sounds like a good method,of the 87 offerings from Best it seems like something there would work !! When I put in -.002 main bearings I just spun the rear main right on in there torqued it slappedd on a fresh pan set,clean pan and went to truckin,is fine after 12,000 miles. I think PCV helps that a lot.Also helps to seal the cap parting line with something the torque -up can squeeze out of there,however I didn't that time. Had the tranny back so the shaft could fall down out of the way.
