| | | Forums66 Topics128,260 Posts1,058,287 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2019 Posts: 80 Jim C. Blue | | Jim C. Blue Joined: Aug 2019 Posts: 80 | Well, last year I did a crazy impulse buy and purchased a turbocharger. The plan was to install it on my little summer car. Figured with all the vehicles I had, it didn't really fit in anymore. So, it was going to become the "fun hot rod". At the time, I didn't put much thought into it and later felt stupid about it. That was made worse by it not fitting. The manifold points directly down, where the motor mount gets in the way. Now I have a useless turbo.
Then I got another thought. Could it work on a 292 six?
The turbo is supposed to be for a 1.5 up to a 2.5, but still seems a bit big for a 1.6, especially when I was going for a mild setup. However, I have heard that when going for a mild turbo, fuel efficiency increase or a faster spooling turbo, to go with a turbo that's one size smaller than what is recommended for the engine size.
However, 292 is 4.8L and wouldn't one size smaller be 3.0 to 4.0 sizes? Would it still be big enough to have any positive effect or not? I'm no turbocharge expert (like I said, I felt stupid) so I'm asking. Alexander's Automotive Assortment- 1953 GMC 9700 3-ton**
- 1978 Plymouth Arrow
- 1980 Jeep J10 Cargo Truck
- 1985 Red Wagon Trailer (for cars)
- 1986 Toyota Tercel Wagon 4wd
**(9700 in Canada or 450 in USA.)
| | | | | Joined: Jun 2023 Posts: 18 'Bolter | | 'Bolter Joined: Jun 2023 Posts: 18 | Without getting into the math , have you considered that you will have to have a blow through carburetor, and oil supply, and return. Then there is the aspect of retarding the ignition as boost levels increase, as well as fuel rate. Also there is the question of if the intake manifold would stay sealed under pressure. As far as size wise, what you would have to figure is how many cfm your turbo puts out at whatever psi you are shooting for versus the volumetric efficiency of the engine , and cubic inches at whatever rpm that you want to be your butter zone, keeping in mind that number needs to come in before you get on top of the cam. You may find that the boost comes in a lot later than your useable RPM, especially if its in a work truck. I m going to assume, because I don t know, that 292 is probably an 8 to 1 compression ratio, so its low enough for boost to make a big difference. What I don t know is where the cylinder head and or bolts quit sealing at say X amount of pressure. I also don t know at what point that the rods will make a windar in the block. 302 Jimmys have had great success in years past under boost, but at the time the aftermarket supported them.
As far as feeling stupid, I gained the knowledge that I have from tearing stuff up. The difference is, what I was tearing up was readily available if the magic smoke was let out of it. I m all for you experimenting. Buy a little welder and some tubing, and go to town. What I would recommend doing though is playing around with easily replaceable modern engines. This also becomes important regarding ring seal. I had a 502 that I had named "dipstick". Even with open element breathers it would blow the dipstick out at around 18 psi of boost.
If you pursue this in a carbureted application, I very much recommend installing a fuel ratio gauge so you don t lean burn. Run a bit fatter than stoichiometric ratio, and let your plugs tell you the tale. | | | | | Joined: May 2015 Posts: 11,262 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,262 | have you considered that you will have to have a blow through carburetor Yeah, that isn't going to work at all. Fuel will blow out the vent (if it gets to the bowl at all) and no fuel will be sucked into the venturi (that's how carbs work with lower pressure in the venturi than outside). You might be able to get it to work if you encase the whole carburetor inside the intake that's going to be pressurized by the turbo.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2000 Posts: 2,213 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,213 |
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jun 2023 Posts: 18 'Bolter | | 'Bolter Joined: Jun 2023 Posts: 18 | https://www.motortrend.com/how-to/build-blow-carb-less-50/https://www.motortrend.com/how-to/proving-compressed-air-supercharging-blow-carburetor/I attempted to reply earlier, but it did not go through. If it does, disregard this post please. None of these carburetors would be suited for your use, but this is the idea. I ve personally modified several Holley carburetors for blow through applications, and it does work. I would never consider doing another one, as tuning was fairly intense. You also get into boost reference, even with your fuel pressure. If your carburetor calls for say 5 psi, and you have say 10 psi of maximum boost, you now have to supply the carburetor with 15 psi of fuel pressure, and that number has to fluctuate in direct proportion with boost pressure or you will be blowing fuel through the needle and seat. There s a lot more to it than that, but it has been done many many times. I can t even imagine trying to modify a vintage carburetor, for boost, as its sometimes difficult to get them sealed up on their own. The holley was unique in that it was simple to swap the power valve out. In my personal experience, a blow through design is good for wfo, and thats it. I managed to drive mine on the street, but it was a handfull. The gift wrapped carburetor in a box has been done as well, and it does work too. Throttle body injection is too easy to install to go the carburetor route in this particular case in my opinion. If you do decide to pursue the carburetor route pm me and I will attempt to guide you through it. I still feel that this would be best suited for a modern engine, but the shock value when opening a hood on something like that has value as well. | | | | | Joined: Dec 2008 Posts: 1,923 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,923 | Picking the size is #1. Then comes another 10 questions... | | | | | Joined: Feb 2004 Posts: 29,940 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,940 | You might be able to get it to work if you encase the whole carburetor inside the intake that's going to be pressurized by the turbo. That's what Ford did on the supercharged 312 engine they brought out in 1957, and started eating Chevy's lunch on the drag strips. Chevy went into a Phase 10 Panic and stuffed their new 348 medium duty truck engine into the 58 Impala, with a 3 2-barrel intake on it. That engine ate valves like popcorn because it couldn't handle the RPM capability those carbs gave it! It started floating valves above 5500 RPM! Jerry
| | | | | Joined: Jun 2023 Posts: 18 'Bolter | | 'Bolter Joined: Jun 2023 Posts: 18 | Ah, the type W rat. I ve had a few interactions with the bigger 409 brother over the years. I have heard of the gift wrapped 312, but never seen one in person. Great memory there . Here is a calculator for the OP on turbocharger sizing. Its rudimentary, but gives an Idea. Since I don't know much about his turbo, he can maybe play with the boost numbers and see what he has and or needs. https://strikeengine.com/turbo-size-calculator-find-cfm-pressure-ratio/ | | | | | Joined: Feb 2004 Posts: 29,940 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,940 | I believe the Kaiser Manhattan used a similar setup on their 1954 model- - - -a flathead six Continental engine with either a Paxton or a McCullouch supercharger and a pressure box around the carburetor. One of the customers at Dad's shop in Nashville back in the late 1950's drove one of those cars. Jerry
| | | | | Joined: Oct 2021 Posts: 7,025 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 7,025 | Packard did the same thing in the mid 1930s
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Dec 2008 Posts: 1,923 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,923 | Paxton and McCullough are the same company, one has fixed drive ratio the other varies with RPM. | | | | | Joined: Feb 2004 Posts: 29,940 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,940 | If you choose to turbo the 292, be sure to add some piston cooling. The turbo Toyota Supra has oil nozzles that spray lube oil to the underside of the pistons, and a big oil cooler onboard. Ditto for a lot of big Diesel engines in tractor-trailer rigs. A Volvo engine I inspected on a warranty claim had piston cooling nozzles, and the top of Detroit Diesel connecting rods used on turbo engines had a spray nozzle built in to direct lube oil to the bottom of the piston crown. Those rods were gun drilled to provide pressurized lubrication to the wrist pins. I worked on dozens of them back in the late 1990's when I ran the rod reconditioning department at a big machine shop In Nashville.
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | klhansen My neighbor in the eighty,s an OLD rodder built a dual turbo 361 ford pickup with a holley 4-barrel in a box with a lexan (so you could see in there) top. It bulged so bad he put bars across the lexan to hold it. He would drive it to the post office of our hick town,it just shook the whole downtown what a piece. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Alex Arrow Don,t give up to easily,I think a mildly turbo-charged stove bolt 235/261 might be a good shot. With hood clearance in a truck you could turn your manifold upside down then you have room. ! have a Buick grand national turbo on the drawing board and dragsix is onboard to try it. Had one turboed but that engine was too far gone. Another thing the turbo should see the fire belch out when the valve opens !! | | | | | Joined: Mar 2010 Posts: 10,335 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,335 | A small supercharger would be my choice for these trucks. A turbo is going to add to much heat under the hood.
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | 52 Carl Turbo Cummins doesn't worry about that heat,guess you could insulate and make it go out the tail pipe. Friend had a chevy that in interstate pull check engine light would come on,they tried everything,he had it traded,another mechanic took the air supply duct off put it in the bed,said try it now ! Check engine light never came on again !! | | | | | Joined: Mar 2010 Posts: 10,335 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,335 | 52 Carl Turbo Cummins doesn't worry about that heat,guess you could insulate and make it go out the tail pipe. Friend had a chevy that in interstate pull check engine light would come on,they tried everything,he had it traded,another mechanic took the air supply duct off put it in the bed,said try it now ! Check engine light never came on again !! I used to drive a Dodge stake body truck with a turbo Cummins in it. That was an amazing setup. The big difference between that setup and adding a turbo to a Stovebolt engine in front of an AD cab is apples to oranges. My fear is that here are too many leaks in the cab where pedals come through. Extra insulation will help, but I fear that it will do little to stop the air leaks in the cab. A lot of heat comes in through those leaks with a stock engine in place.
