| | | Forums66 Topics128,179 Posts1,057,133 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2023 Posts: 443 'Bolter | | 'Bolter Joined: May 2023 Posts: 443 | I'm going to need to replace my ring and pinion and as most know the options are limited.. I've got a 4 speed tranny and was wondering what is a good gear ratio so it can cruise fairly well..
Looking at a 3.55:1 and a 3.90:1
what are pros and cons or options.
Thanks for any help to this backyard mechanic 1954 Chevy 3100One problem solved doesn’t seem to shorten the list Montgomery, ALIn Project Journals | | | | | Joined: Feb 2021 Posts: 98 'Bolter | | 'Bolter Joined: Feb 2021 Posts: 98 | Its going to be hard to find a 3:90:1. I was lucky to find a NOS 3:90:1 on eBay, I need that particular ring and pinion because the truck is 4 wheel drive and it needed to match the front differential. | | | | | Joined: May 2015 Posts: 11,156 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,156 | Your stock ratio is 3.90:1 (but your R&P look bad). In order to use a 3.55:1 gear set, you'll need a differential case from a 47-53 1/2 ton truck. The optional 3.55:1 gearset won't fit on your differential case.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: May 2023 Posts: 443 'Bolter | | 'Bolter Joined: May 2023 Posts: 443 | Thanks for the info. I’ll see if I can find a 3:90
Ps: found a used good condition 3:90 on eBay and ordered it. Said it came out of a 54 3100 and had been stored for about 30 years. Fingers crossed.
1954 Chevy 3100One problem solved doesn’t seem to shorten the list Montgomery, ALIn Project Journals | | | | | Joined: Oct 2021 Posts: 6,947 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,947 | The wonders of modern technology. You located the part almost instantly and will have it in a week or less. How did anybody restore antique cars before the internet?
You'd have been reading Hemmings for maybe months, calling everybody in local and national Chevy clubs, writing letters and posting want ads, and traveling around the country to swap meets. Maybe you'd get the part you needed in 6 months or so.
1950 Chevrolet 3100 (Ol' Roy)
