5 members (GrandpasJimmy, festerhairball, 78buckshot, 2 invisible), 152 guests, and 1 robot.
Topics128,089
Posts1,055,988
Members48,430
#150667 01/30/2007 7:00 PM
I
Junior Member
Junior Member
I Offline
I need a picture of someones firewall to see how your hydrovac valve gets hooked up to the intake. mine is still there just not hooked up [email protected]
also my chevy has a 248 gmc, and there's not enough vacuum lines. should I tee the first fitting into the intake and make more myself? my wipers need hooked up also.
#150668 01/30/2007 7:47 PM
V
V Offline
#150669 01/30/2007 8:01 PM
I
Junior Member
Junior Member
I Offline
you are on it! thanks, it looks as if I can make vacuum ports on that hose from the intake to the vac valve.
