0 members (),
107
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,260 Posts1,058,318 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2023 Posts: 4 Moderated | | Moderated Joined: Jun 2023 Posts: 4 | What does the correct thermostat housing, thermostat, and water pump for a 261 look like and how is it plumbed so that it doesn't overheat on initial startup when the typical thermostat is completely closed? I understand it is critical to always have some coolant flowing and have heard of a dual function thermostat. I would like to see the correct parts and learn how the entire system works. Mine has the typical hoses to the radiator and the loop to the heater, but there is another plugged hole under the top hose to the heater. | | | | | Joined: Feb 2004 Posts: 29,941 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,941 | The "correct part" stopped being manufactured a few decades ago. It's a thermostat with a flapper valve built into it that plugs off a large diameter bypass hose after the engine warms up. With a conventional thermostat, the bypass runs all the time, so there's no possibility of overheating during warmup, or at any other time. The big hose bypass system was only used on heavy duty vehicles like school buses or dump trucks. Unless the heater hoses are disconnected or there's a shutoff valve that completely stops flow through the heater core, there's a large volume circulating through the cooling system as soon as the engine is started. You're concerned about a problem that doesn't exist. Jerry
| | | | | Joined: Jun 2023 Posts: 4 Moderated | | Moderated Joined: Jun 2023 Posts: 4 | Thank you Jerry. OK, but since I'm a newbie here let me ask for clarification. If a hose to the heater has a shutoff valve, which I assume is needed or you'd have hot coolant (oxymoron) and heat in the cab always, and it's shut off/closed, does this prevent circulation through the block when cold starting? Would a "bridge" connection between the heater hoses ahead of the heater core, creating a "primary" loop for circulation that's always open, then the heater valve after that used to allow circulation in the "secondary" loop (heater core) be appropriate? Sounds like the heater valve being closed and stopping the flow could be problematic. Rob | | | | | Joined: May 2015 Posts: 11,262 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,262 | I doubt that closing off the heater hose would cause a problem. That's what the thermostat is for. It opens when the coolant gets warm to allow circulation thru the radiator. My daily driver has no AC, and in hot weather, the cab overheats during short shutdowns, so I installed a shutoff valve. No issues with overheating on cold starts with that arrangement. You could try it and see what happens. Monitor the back of the head with an infrared thermometer on a cold start and watch as it warms up.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jun 2022 Posts: 559 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 559 | You are looking for a problem that doesn't exist. A good waterpump flowing through a good radiator with clear engine passages doesn't care if the truck has a heater or not. Most 261s were used in big trucks running full loads against a governor allowing 3500/4000 rpm's all day long. Many didn't even have a heater, which was a dealer-installed option throughout the 235/261 production years. They came from the factory with pipe plugs where the heater hoses go.
~~ Jethro 1954 3100Back to LifeIn the Dity Gallery1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020 | | |
