6 members (Shade Baby, 46 Texaco, cmayna, baldeagle, Peggy M, 1 invisible), 77 guests, and 7 robots.
Topics128,018
Posts1,055,342
Members48,419
#1506444 06/23/2023 2:59 PM
Crusing in the Passing Lane
When installing the large snap ring that holds turbos(HX35W) in my case, others are similar, together, tight quarters and large stroke are required. I found these straight pliers but no 90 degree selection, drilled a 90 degree hole and inserted pins to offer a second opportunity to get the job done. Large stroke still required another set to get snap ring tight enough. Pliers came from Harbor Freight. Pliers are hardened, so bring a sharp bit, not too fast. .125” pins in my case. Still retained straight function.
Ed
What did you use use for the extra pins? Did you have some hardened rod around?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Needle bearings for universal joints come in several sizes- - - - -they're as hard as woodpecker lips! Air hardening drill rod also works well.
Ace Hardware had a selection of pins.
Ed
Moderated by  MNSmith
