0 members (),
54
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2020 Posts: 103 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 103 | Good morning, I have a 1953 Chevrolet 3600 pick up and would like some confirmation. I was under the impression that the electrical on the Chevy trucks was negative ground and GMC was positive ground. Do I have bad information? | | | | | Joined: Oct 2021 Posts: 6,772 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,772 |
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | Unless it came from Canada A 1953 gmc truck is negative ground on the north ones because they have everything chevy under the hood and the instrument cluster is also all chevy. -s | | | | | Joined: Dec 2020 Posts: 103 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 103 | | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | GMC big rigs were all positive ground. The pickups simply followed suit to keep everything in the brand uniform. Back in the dark ages, commercial truck manufacturers preferred positive ground for some reason. In 1957, all the automotive makers standardized their electrical systems at 12V negative ground. Some commercial trucks stayed with the positive ground for some time afterwards, such as the 64 Freightliner I drove for a while. Jerry
