| | | Forums66 Topics128,042 Posts1,055,520 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2023 Posts: 374 'Bolter | | 'Bolter Joined: Feb 2023 Posts: 374 | Want to install a posi trac unit in my 66 C10 Short stepside. Looking for any first hand thumbs up ( or not ) for the Yukon Duragrip for late '60's 12 bolt truck. Truck has a mild 454 with Muncie 2.52 first gear & 3.08 final drive. Not looking to race , just good overall traction for street use.
Anyone with personal experience with the Yukon Duragrip ? TIA, RB | | | | | Joined: Feb 2004 Posts: 29,755 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,755 | From their website, it looks like the design that's been around since the early 1960's or before- - - -a spring loaded clutch pack that applies anytime there's a noticeable difference in axle rotation speed, indicating wheel spin. It's one of three common designs- - - -friction clutches, cone clutches, and positive locking devices such as the Detroit Locker that actually locks the axles together mechanically. You'll have to learn a new driving style, as once the lockup happens, the vehicle will go wherever the rear wheels are pointed- - - -like off the road to the outside of a turn if you apply enough throttle to activate the locker. They're handy in mud or snow, as long as you adapt your driving style to the altered handling characteristics. Jerry
| | | | | Joined: Sep 2011 Posts: 1,452 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,452 | I've been running a Yukon duragrip in my 1999 Tahoe for several years, works great. Also have a Spicer Power-loc in my 1960 Chevy C10 (has a Dana 44 rear axle from 1960 GMC) which works well. Both have good manners on the road. I also have Yukon designed no-spin in my 2000 K2500 with 10 1/2" rear axle, that one is somewhat squrley on the road but really great in the hills.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Feb 2023 Posts: 374 'Bolter | | 'Bolter Joined: Feb 2023 Posts: 374 | Thanks BC, that's what I was hoping to hear regards the Duragrip unit. Not sure who made your Yukon designed unit in your K2500 & if it's similar to the Duragrip.
Thanks for the general overview , HRL. I've used plenty of posi oem units over the years including in my present DD 2014 Ram 1500. In yrs past I've had a Detroit Locker in a 427 Ford full size car , a Dana 60 in a 426 Hemi Cuda plus plenty of lesser powered cars & trucks. But they were all oem supplied units. I've never used an aftermarket posi so was interested in anyone with real world experience with this particular brand & model before hitting the buy it now button. | | | | | Joined: Sep 2011 Posts: 1,452 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,452 |
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Feb 2023 Posts: 374 'Bolter | | 'Bolter Joined: Feb 2023 Posts: 374 | Thanks. I think the Duragrip is the unit I want. | | | | | Joined: Jun 2023 Posts: 18 'Bolter | | 'Bolter Joined: Jun 2023 Posts: 18 | I ve beat on the truetrac in the Dana 80 in my rock crawler. That truck is really heavy, with 5.38 gears, and I m running a double transfer case with 40" tires. Sometimes it s about wheel speed, and I ve had 40's spinning up to 60mph and snagged a rock. Sure, it pitches the driveshaft, but I ve not torn up a truetrac as of yet. It sees a lot of street time as well, and a heck of a lot of trailers have been pulled with it. I ve ran truetracs for many years. In fact, I had some air selectable lockers in my last crawler, and went with a truetrac in my latest one just because of the simplicity, and the fact that I usually don t even notice that its back there on the street. As a side note, regardless of what kind of truck that you have, the transfer case to use is a np205. I ve even put them in 2wd trucks that I wanted a lower selection of gears. | | | | | Joined: Feb 2023 Posts: 374 'Bolter | | 'Bolter Joined: Feb 2023 Posts: 374 | I ve beat on the truetrac in the Dana 80 in my rock crawler. That truck is really heavy, with 5.38 gears, and I m running a double transfer case with 40" tires. Sometimes it s about wheel speed, and I ve had 40's spinning up to 60mph and snagged a rock. Sure, it pitches the driveshaft, but I ve not torn up a truetrac as of yet. It sees a lot of street time as well, and a heck of a lot of trailers have been pulled with it. I ve ran truetracs for many years. In fact, I had some air selectable lockers in my last crawler, and went with a truetrac in my latest one just because of the simplicity, and the fact that I usually don t even notice that its back there on the street. As a side note, regardless of what kind of truck that you have, the transfer case to use is a np205. I ve even put them in 2wd trucks that I wanted a lower selection of gears. Thanks for the input. My C 10 is a 2WD. For my purposes, I think I'll go with the Duragrip. It seems to me that the lockers are more geared for off road, where as the clutch type units are more general use & street friendly. | | |
