2 members (dt235sd, Jon G),
50
Mod | | | Forums66 Topics128,021 Posts1,055,372 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#1497 08/28/2003 12:49 PM | Joined: Oct 2000 Posts: 98 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 98 | I posted something a few weeks back about my engine missing. I thought it was the carburetor. After adjusting that carburetor and putting on a different carburetor, I'm not sure that is the problem.
The engine is a 250 in a 1966 Chevy pickup. I did a compression test on it a couple weeks ago and all the cylinders registered around 175. However, a couple of them leaked off as it sat. So, this weekend I'm going to repeat the test.
I replaced the plugs and plug wires a couple of weeks ago to see if that was the problem. It did not change anything.
A year or so ago I replaced the points with a Petronix electronic ignitor and the coil with a Petronix coil. At this same time I replaced the vaccum advance and it still works as it should.
I have adjusted the timing so that the engine runs smoother. It is several degrees more advanced than the manual suggests.
Last night while it was running I pulled the plug wires to see if there was any cylinder that did not cause it to run worse. It seemed that when I pulled #1 and #2 wires the engine did not run any worse. It definitly ran worse on the remaining 4 cylinders.
Another thing that I noticed was that when I reved the engine it backfired through the carburetor.
So, any ideas on what the problem might be or what I should check this weekend? Did my timing jump? Do I have a bad head gasket? Do I have some burnt valves? What are your thought?
Sorry for this long post, but I have been working on this thing most of the summer and have about come to my wits end.
Thanks in advance for any help or suggestions you can give.
Mike K.
Mike Kelley 1966 Chevy C10 SWB - 250 L6/S10 T5 2002 Chevy Ext 1500 4x4
Http://myol66.wordpress.com
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Mike, I have always found that checking the engine out with a vacuum gauge can eliminate some possibilities and, if you are lucky, it might identify the problem. http://www.classictruckshop.com/clubs/earlyburbs/projects/vac/uum.htm It's too bad the above site is not actively maintained because it has a lot of useful information. Tim | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Are the #1 & #2 cylinders the ones that leaked down?
If not, it sounds like you you have an electrical problem. First, inspect your distributor cap. Look for burnt or corroded contacts, and look for cracks. If you have another cap on the shelf, I would try it. Another old trick is to do a "dark" test. At night and in the dark, run the engine and look for arcing. If you see arcs from the wire boot to the head or plug, you have a plug with a broken electrode. Arcing between wires is usually crossfiring due to improper wire routing.
Fred 52 3600 69 C-10
| | | | | Joined: Jul 2003 Posts: 132 'Bolter | | 'Bolter Joined: Jul 2003 Posts: 132 | OK, let's go through this: We know it's not wires and plugs, the coil would effect all cylinders, not just 1 & 2. Could be the distributor cap, but not likely. Backfiring is sometimes a symtom of either valves not opening or lean mixtures. So check the valve lift on #1 & 2 to make sure a cam lobe isn't down. That's not likely either because of the good compression. If the backfireing and missing is due to a lean mixture it can't be the carb since not all cylinders are involved. I would look for a vacuum leak somewhere near the #1 and 2 intake runner. Maybe a loose fitting, cracked line or the gasket itself. Squirt a little oil around the manifold to head joint while the engine is running and let us know what you find. | | | | | Joined: Oct 2000 Posts: 98 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 98 | I connected the vacuum guage to the line that feeds the vaccuum advance on the distribitor and it read around 5.
According to what I read it should be 17-22, right?
Did I connect it to the right place?
Thanks for the replies. Mike K.
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You need to connect it to the manifold vacuum. The distributor vacuum is ported and changes with throttle position.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Do you have the #1 and #2 wires swapped? | | |
#1504 08/28/2003 10:49 PM | Joined: Oct 2000 Posts: 98 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 98 | On a Rochester B carb, where do I hook up? Is there another port on the carb or manifold?
Thanks, Mike K.
#1505 08/28/2003 11:25 PM | Joined: Jul 2003 Posts: 132 'Bolter | | 'Bolter Joined: Jul 2003 Posts: 132 | Any connection below the throttle plate will work. | | | | | Joined: Feb 2000 Posts: 5,194 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,194 | Kenc maybe on to something with that vacuum leak. I have pretty good luck using a small hose about 3 feet long and listen for leaks. With one end in your ear use the other and probe around the gasket area. First stick it in the carb so you know what listen for, then start hunting. Most likely spot will be under the intake or bottom side of the front runner. The bolts are spaced a little funny right there and don't hold to well. Keep us posted, Joe. | | | | | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | | | |
#1508 08/31/2003 11:55 PM | Joined: Jul 2003 Posts: 132 'Bolter | | 'Bolter Joined: Jul 2003 Posts: 132 | Hey Mike, Let us know what you found. curious minds want to know. | | |
#1509 09/02/2003 12:27 PM | Joined: Oct 2000 Posts: 98 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 98 | I didn't get a chance over the weekend to look into it. As soon as I find something out, I'll let you know.
#1510 09/16/2003 12:38 PM | Joined: Oct 2000 Posts: 98 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 98 | Update...I did a compression check this past weekend and felt like the leaking off was not in the cylinder but in not having the guage sealed good. My dad suggested a new distributor as the old one had some slop in it. I bought a new one and put it in, but the miss is still there.
So, I gave up and took it to a local repair shop to have them tell me what the problem was. In driving it there I noticed that it was pinging real bad, I must not have the timing set just right. Also, the miss was not very noticable when you were driving. Wonder what that means.
Anyway hopefully in the next day or so I'll hear from them on what they think the problem is.
| | | | | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Check your spark advance curve, both mech and vacuum. Six cylinders will develop a stutter that seems to be missing, but its actually incorrect timing.
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
| | | | | Joined: Oct 2000 Posts: 98 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 98 | Well, I got a call today from the mechanic. He said they adjusted the air/fuel mixture and set the timing. He stated that it "pulls out real good". Hopefully, I'll be able to pick it up today and see for myself.
Mike K.
#1513 09/19/2003 12:44 PM | Joined: Oct 2000 Posts: 98 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 98 | Well, I picked the truck up last night and it runs like a top. The mechanic would not share his method of fixing it. Said that he set the carb and timing by ear. He told me that he grew up on this motors. He would not tell me what he did because I would go buy Craftsman tools and do it myself. Whatever....
I'm just glad it runs good. I drove it around last night just to make sure it would be up to a trip to the ATHS truck show tomorrow.
| | | | | Joined: Sep 2003 Posts: 37 Junior Member | | Junior Member Joined: Sep 2003 Posts: 37 | Well dangit! I sure was hoping to hear the fix for this one. Too bad my truck sounds similar and I can't get it to MO. I'll be checkin' on those vacuum leaks... | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | That means it was so simple he doesn't want to tell you because then he can't charge what he did.
54 3100 with 235 62 flatbed dump C60 with 261
#1516 09/19/2003 10:34 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Well, if the mechanic did the work for free he wouldn`t be in business now would he :rolleyes:
| | | | | Joined: Sep 2003 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 37 | Read through all the replies, all good advice, and here's my funky addition that may or may not be of use... What was the AIR TEMP OUTSIDE? I have found that with all else working, monojets seem to like to ice up if the hot air stove from the manifold is missing or rotted out. Really. If it starts and runs well above about 5 degrees above freezing and below about 5 below, but stumbles, stalls, and runs like crap between, and if you shut it off for 5 min then and it restarts and runs smooth for another 5 before it starts acting up again.... There is quite a temperature drop as the air speeds up through the venturi, and it will freeze the water vapour in the air, stick to the bore and mess up the actual venturi effect, and block the idle passage too. you can keep it running with lots of throttle of course. I think below about -5C (27F) that the relative humidity is too low to sustain the effect because mine would clear up about then. Took me a year to figure that out, and since have run into it on 4 seperate trucks - each one ran perfectly again with the hot air inlet repaired. | | |
