3 members (Bill Hanlon, ShopRag, 1 invisible),
67
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,676 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2021 Posts: 86 'Bolter | | 'Bolter Joined: Feb 2021 Posts: 86 | Folks, my 1950 chev ute has a closed torque tube setup the rear diff, looking at changing the diff from a later model vehicle but it means i need to do something with the existing torque tube setup.
I remember reading something about a conversion kit that allows you to keep your gearbox but switch over to open driveshaft.
Any chance someone can ellaborate or someone who has done it send some photos through
Would be greatly appreciated
Steve | | | | | Joined: Oct 2021 Posts: 6,746 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,746 | I doubt there's a kit. You'll have to have a drive shaft custom made.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: May 2015 Posts: 11,031 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,031 | The issue with close driveshaft transmissions, is that the transmission oil lubricates the u-joint. Even if you can get a more modern grease lubed u-joint yoke on the transmission, you'd still have to find a way to seal the rear of the transmission where the yoke comes out. Given enough money and a capable machine shop, it would be possible to modify the transmission, but a switch to an open driveshaft style gearbox would be much easier. The open driveshaft is the easy part, modifying the closed driveshaft transmission is harder.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2021 Posts: 86 'Bolter | | 'Bolter Joined: Feb 2021 Posts: 86 | Couldnt get anything shipped, been a couple of years and was hoping something had turned up on the market, hence the re asking of my question | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | It would be possible to eliminate the torque tube ball and replace it with a stub shaft and a sealed ball bearing, mounted to a piece of plate steel or aluminum that bolts onto the bolt circle on the back of the transmission where the ball retainer would normally fit. Use the front section of the existing U joint to mate with the trans output shaft, and adapt a square flange to the back of the stub shaft for an external U joint. It would be a fairly simple project for a competent machinist. Jerry
| | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | Which transmission do you have?
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Why not do it like General Motors did it in 1955. A 1955 and later transmission and rear from a 1955 and later will have will have an open drive shaft. But remember that the torque tube kept the rear axle from torquing and the axle seats were hinged. Either weld the hinges tight or fabricate axle seats or modify some from a trailer. Just make sure you keep the same pinion inclination angle. From your first post it sounds like you have a rear that will work. A 1955 or later pickup or passenger transmission will work. | | |
