4 members (jmoore, TUTS 59, 68ironhead, 3B), 105 guests, and 4 robots.
Topics128,026
Posts1,055,404
Members48,422
#1504615 06/10/2023 5:25 PM
Don't know where this rubber seal goes. AF 173, C-104T, 1941 clutch/brake floor seal. Should there be 2 of them?
1942 Chevy 1/2 ton
2014 RAM Truck
Gary42 #1504703 06/11/2023 2:37 AM
That looks like the clutch pedal arm bumper that cushions the arm from smacking the firewall.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Gary42 #1504748 06/11/2023 2:26 PM
Gary,
Mike is correct!
The seal also surrounds your steering column. See the part "description" better explained HERE.
IIRC there was a recent discussion on this item and I think it gets sandwiched between the cab toe-board and a second metal plate that keep all in place around your steering column and brake/clutch pedal rods going through the toe board.
Dan
~ Dan
1951 Chevy 3 window 3100
Gary42 #1504786 06/11/2023 7:56 PM
Those are actually just bumpers, not seals. They're the same for AD series trucks and go on the lever arm that extends up from the pedal pivot shaft up along the toe panel and below where the pedal shafts go thru the floorboard. They go on the Lower Pedal Assembly per the attached pic from the 47-54 Factory Assembly Manual. Red arrow shows the location, although they don't show up on the figure. They were on my truck originally, but pretty deteriorated.
Pedal Assembly
Gary42 #1504906 06/12/2023 2:39 PM
Kevin,
He appears to be working on a ‘41-‘46 (‘42 I think) truck.
That set up is different than the AD series info you mentioned.
Two different aminals. 😉
Dan
~ Dan
Gary42 #1504921 06/12/2023 5:21 PM
Think I have it figured out. And yes it is a 42.
1942 Chevy 1/2 ton
2014 RAM Truck
Gary42 #1504945 06/12/2023 8:54 PM
Glad to hear you got it figured out Gary. thumbs_up
Got any more current pictures of your truck? I saw the ones you have posted in your Forum Gallery post and was interested if you have any more you would like to share?
Dan
EDIT: Gary, sorry if my replies didn't quite hit the mark. Looks like you changed your question and the picture of the part you were asking about (the thread title still says "Floor seal") from the felt seal picture and I didn't catch that change. Sounds like you got what you need, so will move it along. wink
~ Dan
Moderated by  klhansen, Rusty Rod
