| | | Forums66 Topics128,068 Posts1,055,882 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 127 | Would like some help with the VIN# After some resherch I found out it is a 1959. the VIN# is D862S5357U would like to know what the U stands for? THANKS FOR ANY HELP DON | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | did you try the vin buster on this site? not sure what years it covers now but you can get to it from the news page | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Mr. Giant, I'm no expert and I'm a Canuk to boot but I'll give it a shot, here goes D = Diesel engine 6-71E 862 = Truck model, four different wheelbases possible depending on whether it is a 1st, 2nd, or 3rd series S = production year I believe 1958 5357 = regular production number U = I can find no mention of this letter in this position As I said I'm no expert, I could be out in left field, but I hope this helps some. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the vin buster here only talks chevy - might find something at GMCtrucks.com Bill | | | | | Joined: Jan 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 127 | thanks for all your help, when i got the truck I was told it was a 1957,but was told that was wrong.I am trying to get it wright before I title the truck with the D.M.V. I thought the U was where it was bilt ? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the S was used for both 58 and 59 ... no idea what the U is, but it isn't where built, as there's no GM plant that starts with a U
Bill | | |
