Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
3 members (Woodcmiami, newtonlr, moparguy), 613 guests, and 1 robot.
Topics126,776
Posts1,039,259
Members48,100
Most Online2,175
Jul 21st, 2025
I'm stuck (literally) on trying to change the wheel cylinders for the brakes on my 1937 Chevy 1 1/2 ton truck. I've got the wheel off and took all of the inner nuts off (see attached picture), but I can't get anything to budge. I was expecting things to come apart with the nuts off, but nothing moves. This is my first attempt to change wheel cylinders on anything, so I'm sure I'm missing something obvious, but I don't know what it is. Any and all suggestions are greatly appreciated...
Thanks!
Brian,
Just a note here that I have moved your post to the Driveline forum as the better place for your topic.
Am sure folks will be along soon to try and offer some help and guidance.
Best Regards,
Dan
~ Dan
1951 Chevy 3 window 3100
O Online: Content
Doesn't it come off with the wheel bearings like most front drums? Take off that nut in the center.
Do you have a shop manual?
1950 Chevrolet 3100 (Ol' Roy)
1939 Packard Standard Eight Coupe (The Phantom) | 1956 Cadillac Coupe de Ville (The Bismarck) | 1956 Cadillac Sixty Special Fleetwood (The Godfather) | 1966 Oldsmobile Toronado (The Purple Knif) | 1966 Ford Mustang (Little Red) | 1964 Ford Galaxie 500 coupe | 1979 Ford F-100 | 1976 Ford F-150 (Big Red) | 1995 Ford F-150 (Newt)
Ok I will try taking the center nut off. I do have a shop manual. Unfortunately the first line of the instructions are "Jack up the car and remove wheel and brake drum." The instructions move on from there... Thanks for the suggestion.
Brian,
Your description of the lack of info in the shop manual is spot on. frown
However, the Parts Catalog covering your '37 1-1/2 Ton provides a nice disassembled picture laying out all the parts involved (see screenshot below) which should help you find your way through this process.
The info was found on this page from the entire Chevrolet 1929-41 Master Parts Price List resource document. The name of the book kinda throws you off track as it seems to indicate just a "price list", but it actually has the full parts listings and diagrams regularly found in the later Master Parts and Accessories Catalogs.
Hope this may prove helpful?
BTW - The tip from Otto on removing the cap is correct as it allows you access for then removing the hub bearing retaining hardware, bearings and eventually the hub with brake drum from your axle.
Come back and let us know how this works.
Dan
Truck front axle - hub - brake drum parts 1929-41 Chevrolet Master Parts.png (238.01 KB, 99 downloads)
1929-41 1-1/2 Ton front axle hub and brake assembly diagram
~ Dan
Put the drum to hub nuts back on the studs, you don't need to remove them to take the drum off to get to the wheel cylinders. Them remove the hex cap in the center of the hub, remove the cotter pin, remove the spindle nut, remove the washer and outer bearing and then slide the drum and hub off as a unit. Note, if the shoes are rusted to the drum you may need to loosen the shoe adjustment to free it up.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1956 8400 Wrecker w/Holmes 525
1956 9200 Tractor w/Allison Automatic
1952 Willys M38 Army Jeep
1953 Willys M38A1 Fire Jeep
1978 Jeep CJ-5 Navy Jeep
1984 Jeep CJ7
Hughesville, MD
Thanks for the help on the front wheels. Once I took the cap off and took the center nut off, they came off easy. Now I'm stuck on the rear dual wheels (Imagine that!). I've got the wheels off, took the center bolts out and pulled the axle out. The drum spins, but won't come off. I'm guessing there is something that I'm missing, but I'm not sure what it is. Can anyone provide some guidance?
Brian
That circular nut on the axle housing load tube behind the axle flange needs to be removed. Actually, there are two nuts, with a locking ring between them. Bend the lock ring tabs back from the outer nut and loosen it with a hammer and punch if you don't have the special wrench made to engage the slots in the nut. I make my own spanner wrenches by welding four pieces of square key stock to a piece of pipe and grind or file the key stock to get a snug fit in the slots in the nut. Then drill a hole through the pipe and use a piece of round steel bar for a tee handle.
Thanks for the instructions. I was wondering if that was a lock nut on there, but wasn't sure. I'm going to try to find someone that has a wrench or socket that will fit the lock nut. I'm afraid I'll mess it up if I try to remove it without one. I appreciate the assistance.
Brian
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.032s Queries: 17 (0.028s) Memory: 0.6368 MB (Peak: 0.7339 MB) Data Comp: Zlib Server Time: 2025-09-22 01:45:18 UTC
Valid HTML 5 and Valid CSS
