3 members (Hotrod Lincoln, delky, Southerntruck), 65 guests, and 3 robots.
Topics128,080
Posts1,055,952
Members48,430
#1504197 06/08/2023 1:18 AM
8
nothing beats a try but a failure
8 Offline
I block sanded up to 400 grit on my 54 cab, but at the seam were the A pillar meets the cowl I sanded thru to bare metal. I am close to painting the cab but I wanted to address this issue before I proceeded to paint. How would you move forward in respect to the metal brake thru?
1955.1 3600 5 window 4 speed all original except the 410 gears.
In the Project Journal
87GN #1504198 06/08/2023 1:26 AM
I would shoot a little more primer on that spot. Then be a bit lighter on the sanding.
87GN #1504209 06/08/2023 3:20 AM
Re-prime.
87GN #1504240 06/08/2023 1:44 PM
I’m currently taking a body shop class and we discussed burn through. As the other posts said, just re-prime and go easier on the sanding. For burn through it’s common practice to touch up the burn through with a rattle can if you only have a few small spots. BUT, TO GET PROPER ADHESION it must be the same manufacturer and type of primer.
For the work I’m doing on the bed steps of my ‘55, I was able to get the same Nason primer in both a quart and rattle can from our local Kemperle Inc distributor, for the situation that you’ve encountered.
1955 Chevy 2nd Series 3100 Stepside, 235cid
