2 members (RoadsScholar, 1 invisible), 154 guests, and 2 robots.
Topics128,087
Posts1,055,976
Members48,430
#1504129 06/07/2023 7:15 PM
Crusing in the Passing Lane
On my ‘55, I found that mid size trucks, IHC, Navistar, etc., with 466 etc., engines, have elbows that fit 4”, 5”, 6”, 7” turbos, piping and air filter housings. Real handy without having to reinvent the wheel. Find an appropriate size wrecking yard. Picture shows 6bt in my ‘55.
Ed
Ed,
Just a note that I have moved your post to the The HiPo Shop as the topic better fits into that forum.
Best Regards, Dan
~ Dan
1951 Chevy 3 window 3100
You can buy those from a good plumbing supply house like Fergeson in the sizes you mention including adapter elbows with different diameter ends. They're usually made by Fernco and colloquially referred to as such.
https://www.supplyhouse.com/Fernco-...2yGByQw75jcJX4cJjzGnT6xgX5RoC6WgQAvD_BwE
1950 Chevrolet 3100 (Ol' Roy)
I have bought silicone elbows for that purpose. There are available in a variety of sizes and colors.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
The tightest joint is an aluminum tube with a bead rolled near the edge so that the clamp can't slip.
Ask me how I know that...
That is what we had to do on a buddy's duramax to hold the boots above about 50psi. They seem to be holding fine at 80psi.
Rolled beads are not necessary on intake plumbing unless unusual alignment is required.
Ed
Intake plumbing under pressure requires it. i.e., after turbos, etc.
AND sometimes some additional help. A trick I've used on my Diesel is some liquid laundry detergent on the connections. A light smear dries up and glues them together.
