3 members (Paul Mullen, delwrench, Jims46), 63 guests, and 1 robot.
Topics128,077
Posts1,056,280
Members48,441
Hey everyone,
I'm new to this forum. I inherited my grandfather's 1952 Chevy 1/2 ton pickup! I've been driving it around for the last two years and trying to figure out how to work on it myself. All of this is new to me but it is A LOT of fun! I have a question about the transmission oil. The manual calls for 1 1/2 pints of 90 weight gear oil to be put in the transmission fill hole. I have seen some who also put oil into the ball housing/universal joint filler plug hole. Manual says this isn't necessary because that joint gets its lubrication from the transmission. Does it help to put a few ounces in the universal joint filler hole? Will this overfill the transmission? If so, is there any harm in having a little more in there?
Any help on this topic will be greatly appreciated!
Pastor Matt
52 Chevy 3100
Jesus said to him, "I am the way, the truth, and the life. No one comes to the Father except through Me." -John 14:6
I let the tranny oil seep down into the ball joint. Regarding overfilling the tranny, assuming you have a SM420, I fill mine via the side plug until the oil gets to about 1/2"-1" below that hole.
Craig
If the housing gets overfilled the lube will seep out of the input shaft area and contaminate the clutch. If there's wear in the driveshaft bushing just behind the universal joint ball, the lube can seep down the torque tube and overfill the rear end, resulting in leakage at the rear axle bearings and brake contamination. Since the spinning gears in the trans splash lube all over inside the case, if you can touch the oil through the fill hole in the side there's plenty of lube in the case. A slightly low oil level is better than over full. Don't use fancy synthetic lubes in a stovebolt transmission- - - -plain old 90 weight mineral oil is all it needs.
Thank you!
52 Chevy 3100
Short answer to the question "Can you overfill transmission?" is "Not for long." wink
Pastor Matt,
Just a note to say "Welcome to the Stovebolt Community" since these are your very first couple of posts.
We would love to see some pictures and learn more about you and your truck that you've "...been driving it around for the last two years...". thumbs_up
Perhaps you would re-introduce yourself and your truck in our Welcome Centre?
You also might like to drop a note in The Southern Bolters forum and say hello to other Bolters near you.
Catch you in the various forums as your need for info takes you.
Dan
~ Dan
1951 Chevy 3 window 3100
HA! That's what I want to avoid.
52 Chevy 3100
If you look at Page 4-10 of the service manual (the rear axle section), it says to put 1/2 pint of transmission lubricant thru the hole at the rear of the transmission. It says nothing about lubricating the u-joint in the transmission and u-joint sections.
