0 members (), 166 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
#1503804 06/05/2023 10:47 PM
2 Offline
My seat was recovered and I removed it and noticed the material at the bottom of the seat frame is getting cut from bouncing up and down. The material raps from front side under the frame to the back of the frame. It rubs on the bottom metal part that is welded to the floor and goes under the seat and sticks up from floor about 6 inches. that welded part goes around both sides and across the front Is there something missing? is a 1951 chevy seat.
29tons #1503807 06/05/2023 10:57 PM
Pictures of the seat and where it resides in the cab would go a long way towards helping determine what may be the problem.
Can't tell if something is incorrect or missing unless we can see what your working with.
If you need guidance on adding pictures, check out this helpful post.
If you still need help after following those guides, drop me a PM and I will be glad to try and help out. thumbs_up
Dan
~ Dan
1951 Chevy 3 window 3100
29tons #1503858 06/06/2023 2:25 AM
Sounds like something is missing to me.
Here are some pics that show the seat mounting in my '51. First is the riser that's welded to the floor with the seat adjuster rails bolted to the riser. Then pics of the seat bottom springs and the seat back, both from the back side. They fit into the seat frame that bolts to the adjusters. Then a picture of the Factory Assembly Manual page (Section 1, Sheet 2.00) showing the seat frame. The factory upholstery doesn't go under the seat springs.
SEAT RISER AND ADJUSTERS
SEAT BOTTOM SPRINGS
SEAT BACK SPRINGS
SEAT FRAME PAGE
29tons #1505500 06/16/2023 10:15 AM
2 Offline
thanks for the help
29tons #1505621 06/17/2023 12:44 AM
Yes, a couple pics would be very helpful.
Craig
29tons #1505654 06/17/2023 11:35 AM
AD Addict & Tinkerer
There is a skirt on both sides that sounds like your missing. Here is a picture of mine.
Phil
Project Journals
Stovebolt Gallery Forum
Moderated by  ndkid275, Phak1
