Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (Phak1, Otto Skorzeny, Frank50, Crimson48, 55shaker, JW51), 63 guests, and 0 robots.
Topics128,007
Posts1,055,275
Members48,418
#1503737 06/05/2023 2:31 PM
I have used internal resistor coils in the past to eliminate the ballast resistor but on latest project the points are overheating and turning blue. Voltage is 13.8 and one of Jon's condenser upgrades. Any suggestions? Thank you; Evan
Evan
coilover #1503744 06/05/2023 3:24 PM
Moderator, Electrical Bay
Evan what color is that condenser? Red is one of the original ones (in which there were 2 or 3 recorded failures). Gray is the improved one. Please let me know via this forum or by PM.
~ Jon
coilover #1503745 06/05/2023 3:33 PM
Riding in the Passing Lane
You should use a resister & matching coil. Coils with extra resistance are for tractors & other low rpm engines.
George
1972 Chevy c10 Cheyenne Super
coilover #1503898 06/06/2023 1:44 PM
Jon,
It is a grey one.
Evan
coilover #1503910 06/06/2023 2:25 PM
Hmm. That's the good one. Nothing should make that one misbehave and all are tested twice before I use them. I'd be inclined to see if a ballast resistor will help and if so either get a new coil or hide the ballast resistor somewhere.
~ Jon
coilover #1503926 06/06/2023 4:18 PM
Evan: If you are already using a coil with an internal resistor adding an external resistor wouldn't be a good idea.
coilover #1503959 06/06/2023 7:58 PM
Wire an accurate ammeter inline with the coil temporarily- - - -the current draw should be less than 5 amps with the engine running. Either swap coils or add a resistor to keep the current draw down to a level the points can handle. At an applied voltage of 14, the resistance of the primary winding should be about 3 ohms.
Bill Hanlon #1504011 06/06/2023 11:32 PM
I'm thinking there's a chance the internal resistor has failed and in the process of failure has now become a conductor...at least it sounds like that's a possibility.
~ Jon
coilover #1504038 06/07/2023 2:04 AM
Most resistors fail open, not shorted.
coilover #1504047 06/07/2023 2:23 AM
An "internal resistance" coil does not have a resister in it. It has more windings on the primary side which gives it more resistance. If it was that simple all manufactures would have used that kind of coil instead of having a ceramic resister or resistance wire in the harness.
George
coilover #1504054 06/07/2023 2:38 AM
Cold starting is much better if a low resistance primary winding is used for a hotter spark while the battery voltage is low because of the heavy current draw of the starter. Once the charging system kicks in, a resistor is needed to protect the points from overcurrent. The resistor is bypassed during cranking. The engineers who designed that system didn't just fall off the turnip truck on the way to the big city from the farm!
