1 members (Hotrod Lincoln), 77 guests, and 4 robots.
Topics128,271
Posts1,058,312
Members48,485
#1503710 06/05/2023 12:21 PM
Hello have 51, 216 what kind of aftermarket coolant temperature sensor are you using?
1953 with a 216
Luray,
That answer to that question depends on what you are using for a gauge???
The original gauge and sensor where a factory sealed/connected set with a non-detachable temperature probe.
Are you replacing a bad existing original gauge, or looking to use something else???
Dan
~ Dan
1951 Chevy 3 window 3100
I have dolphin 5" quad gauges.
1953 with a 216
I'd ask Dolphin that question.
