1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
#1503336 06/02/2023 8:40 PM
How durable is the stick on pen stripping. I used the stick on letters for my tailgate and they have held up great.
Dave from Northern Kentucky
My 54 3100
Stick on pin stripes on my mom's 1995 F-150 still look like new and are not peeling off.
1950 Chevrolet 3100 (Ol' Roy)
7
7 Offline
I use self-adhesive pin strip in the mid seventies and it held up real well, don't know anything about current products.
Moderator, Electrical Bay
If it is the stuff made by 3M or Cal-Stripe, it will be ok. I used some on my truck and between 1977 and 2020 it never looked any different than it did when new. I think I still have some of the roll I bought back then. Silver and maybe 2.5mm wide. A friend used some generic stuff and it was horrible. Back in the 70s (and maybe it is still offered) there was a masking tape product you applied and then removed the top layer. It left two pieces of masking tape spaced evenly apart and you could take pinstriping paint and a small brush, paint the exposed part and have a genuine painted pinstripe. You could also get that in dual line (one thicker one thinner) that some guys used on wheels, but I watched a pinstripe specialist do twin stripes on 4 wheels in no time at all. I doubt I could ever do this, but he had a helper jack one wheel up at a time while he rotated them and carefully painted both the stripes at once with his other hand. His brush had two long thin sets of brush hairs...one made a thin and one was wider, set about 3/8 inch apart. No tape and he didn't make a single mistake. It was amazing to watch.
~ Jon
Sounds like I will give it a try. I think it is 3M but I will confirm.
My 54 3100
Mine is 3M going on 22 years now, still looking good. When applying, hold 2 to 3 feet of tape out away, then slowly apply, the longer you keep it, the straighter you can site down it. I went right over the door seams so the stripe would be straight from body across the doors, then sliced and rolled 1/2 on door and 1/2 to the body at each seam. Don't pull so tight you stretch it when trying to keep a straight line. We decal a bunch of school buses every year at work, our painter uses a 50/50 mix of water and alcohol when he puts on decals. It allows for some quick adjustments yet drys really quick. Soapy water also works but takes forever to dry out.
