1 members (Dusty53), 174 guests, and 4 robots.
Topics128,101
Posts1,056,180
Members48,436
#1502876 05/30/2023 9:50 PM
I’m assuming this a Carter but I can’t find any identification on it.
1954 Chevy 3100
One problem solved doesn’t seem to shorten the list
Montgomery, AL
In Project Journals
Riding in the Passing Lane
That is a Rochester model B. It is an early model about 1950-1955. with manual choke.
George
1972 Chevy c10 Cheyenne Super
Thanks George. If it doesn’t work I’m going to replace it with a Carter.
1954 Chevy 3100
Montgomery, AL
In Project Journals
Moderator, Electrical Bay
That is an excellent idea. You could use it as a doorstop, bookend, paperweight or trot line weight. Those were well-designed for those things.
~ Jon
The Rochester B has a well-deserved bad rap around here. But I’d hazard a guess that more Bolters are running them, than those than are running a YF. When I see a Stovebolt-powered vehicle, be it a car or truck, at a show…9 times out of 10 it’s running a Rochester.
I made the change to the YF and wouldn’t even think about going back. But depending on your goals and willingness to -~make~ the Rochester B work….it can be made to work.
It would take nearly zero effort, and very little money, to throw a kit in yours and see what happens.
1951 3100
I agree with JW51. Besides, you might find that if you have a Carter YF that does not have the cable brackets for choke and throttle and you want them....that bracket can be a bit pricey.
I still have the Rochester B on my 1954. Its not a daily driver, but it starts every time and works well.
Ron - - Dusty53
1954 Chevy 3604
Thanks for the suggestions guys.. I'm going to put gas in the tank this afternoon and try starting it.. if the carb is the bad link I'm going to order a carter straight away. I still remember running carter 4 barrels in my w57 chevy backy in the day.. never had a problem.
Just in case I need it do you have suggestions on where to get a quality new or rebuild YF
I'll update later on how the start up went.
1954 Chevy 3100
Montgomery, AL
In Project Journals
As others have pointed out, the Carter YF is the superior carb, but think about how many millions of miles those Rochester B's serviced in these trucks and other applications? Do a proper rebuild on one, without skipping any steps or cutting corners, and they are a good serviceable carb. Just my two cents.
1953 Chevy 3100 4 spd
Carburetion specialist
Dusty is correct on the cable bracket.
We give customers the option of a carb with bracket or a carb without. We subtract $50. from the price for the carb without the bracket.
Jon
The Carburetor Shop
Update on carb.
Didn’t get around to putting gas on until this morning and tried to crank it. Had gas leak at the fuel pump intake side. The 5/16 fitting was gauled beyond repair. Trip to hardware was fruitless but found a barb that would fit so went with it.
Ohh I was glad I put a shutoff valve on the line 😁
Got that fixed and poured more gas in the carb a couple times to get it started. On the third try it stayed running. I cut it off after about 40 seconds and got the water hose and filled the radiator and had a major leak.
Freeze plug had a hole on it. Cleaned it as good as I could and when I finish this post going to mix up some JB weld.
Will let you know how that goes tomorrow after letting it set up overnight.
Cheers and wish me luck
1954 Chevy 3100
Montgomery, AL
In Project Journals
You should just knock the casting plug in and replace it.
1950 Chevrolet 3100 (Ol' Roy)
Doug,
Guessing that you are looking for a short-fuse temporary solution to the failed plug.
I would suggest if you can't readily replace it with a new metal compression plug, pull out the failed plug (you should be able to hook it and pry it out) and then replace it with a temporary freeze plug like this one available from your local FLAPS.
Just get a basic diameter measurement and go to your nearest FLAPS and pick one up. These are frequently kept in stock just for situations like this.
As noted on the plug, make sure it and the surrounding surfaces are dry when installing for it to work as designed.
Dan
~ Dan
1951 Chevy 3 window 3100
I have to agree with Otto. Just replace the plug with a proper one. Easy enough to get out by screwing a lag screw in and prying it out with a prybar. The replacement just taps in (after cleaning the hole.)
The JB Weld approach is a bad band-aid fix. Who's to say there isn't another hole ready to rust thru right next to the one that's leaking? Why do the job twice?
Guys this plug is in a hard to reach place. I'd have to hang upside down with the hood off to even see it.
If this bandaid doesn't work I will have to do something just don't know how I'll get to it..
Thanks for the ideas and suggestions..
1954 Chevy 3100
Montgomery, AL
In Project Journals
Try raising the truck and going at it from the bottom. If that plug is rusted through (as it seems) the lag screw/pry bar method might or might not work. That is to say I've had those which didn't have enough metal left in them to let me get them out that way. But if you're patient and resourceful, you'll get it. As for a Carter carburetor, I don't currently have what you'll need, however if you will send me a PM I can mention some other ideas.
~ Jon
1 Offline
I suspect that you might have to bite the bullet and remove the manifold assembly, in which case do all of them.Have a nut splitter handy to avoid snapping the exhaust flange bolts. IIRC there are two core plugs on that side of the engine. If that one is rusted through the others are probably not far behind. They are available in bronze which will forestall a repeat of this to beyond our lifetimes. There is also one on the back of the block that's partly covered by the bell housing and up against the firewall. Fixing that one entails removing the bell housing, which is a lot of dirty work. One might have to pull the engine to get at it; I haven't tried. I dread that day should it come for me.
Last edited by 1Ton_tommy; 06/06/2023 5:21 AM. Reason: By Moderator to correct spelling.
1951 3800 1-ton
In the DITY Gallery
Got engine running again last night and it purred like a kitten... have a unusual noise I hear in the cab but not the engine compartment.. I'll work on that.
Good news is looks like the carb is working fine... and the freeze plug leak is plugged.. smile
I have another leak that is a drip so I'll run that down.. a drip I can handle.. I remember many times I had cars as a kid that I drove around from one filling station to another putting water in it.. this isn't that bad..
Thanks for all the support and suggestions.. I'll keep the journal updated as things progress.
1954 Chevy 3100
Montgomery, AL
In Project Journals
Well wouldn't you know it.. after finally getting it running last night it purred like a kitten.. idled right down and stayed there so carb is not an issue..
see my other post.. have a cracked block that is dripping now... out comes the JB weld again.. this is how we fixed things when I was young and poor..
Now I'm old and poor.. ha... seems some things never change.. I'm going to tackle this problem tomorrow... I'll attach the pics of Ole Smoky's cracked head..
Opps.... will have to edit them in from the ipad.. desktop doesn't have access to them.. lol
btw I'm too stubborn to give up easily..
1954 Chevy 3100
Montgomery, AL
In Project Journals
After I de-greased my truck's engine when I got it, I discovered a sloppy JB Weld repair on the driver side rear that had been done who knows how many years ago? It's ugly but works just fine. That's the advantage of a zero pressure cooling system.
After the JB Weld has had a chance to slightly harden, you can press a piece of course sandpaper or something into the repair to make the surface resemble cast iron. Once painted, no one will know.
Thanks Otto. That gives me more confidence the patch job if done right will last a while. The sandpaper trick is a classic. Love it
1954 Chevy 3100
Montgomery, AL
In Project Journals
