2 members (Otto Skorzeny, 1 invisible),
92
Mod | | | Forums66 Topics128,031 Posts1,055,433 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 63 | can i put 11.00x20's on my '65 C60 | | | | | Joined: Mar 2005 Posts: 25 Member | | Member Joined: Mar 2005 Posts: 25 | That size won't work on the C-60 rear, they are to wide, I have a C-60 with 900 X 20 and they work good, it makes a differance in the type of wheel you have also. | | | | | Joined: Dec 2006 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 63 | could i use them for the front? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | prolly not, originals woulda been about 8.25 - would rub on turns
Bill | | | | | Joined: Dec 2006 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 63 | but would they fit on my rims? | | | | | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | well, uhhhh, yeah, but you can't put them back on the truck, well not on the rear, but maybe the front, but then they would rub on the turns so ya couldn't turn the wheel.
i'm thinking there's an evil plan here i can't comprehend.
let's see.
a truck that can't roll, or turn.
AH HA! I GOT IT!!!!!! | | | | | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | | | | | | Joined: Dec 2006 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 63 | When you say it will rub, where exactly will it rub at? If it is the fenders, nothing that a little modification wont correct. If it is the frame section during turns, I am sure that can be overcome as well. (Keep in mind, my C60 is going to be a custom car hauler, not restored) | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | oversize tires on the front will rub on and damage steering components and limit your turning radius by hitting the frame, but hey! that can be overcome ... just put the right size tires on! Bill | | |
