2 members (60steve, 78buckshot), 75 guests, and 1 robot.
Topics128,212
Posts1,057,468
Members48,471
Hello Stovbolters
Anyone know of an effective easy way of cleaning a breather tube?
Miguel A Ruelas
I soaked mine in Kerosene and then let it dry out.
Others will hopefully chime up on their methods.
1950 Chevy 3100
Same as Shaffer said. I used gasoline.
Others have said they burn it out with fire and repaint it when it's clean.
Of course the tube has to be removed from the engine, Rock it back and forth and use a rubber mallet if necessary and it will come loose.
1950 Chevrolet 3100 (Ol' Roy)
stovebolt newbie Yes burn it with gasoline,pound out the ash,wash clean in solvent. Used to run those thru the caustic tanktoo.
1 Offline
You can also remove the cap to get access to the oil separator. Knock the cap off from the inside with a wood dowel and a hammer, it's just crimped on. Use a little gum-pucky to seal it up when you're finished. This is less scary than burning it, which I have done with a torch and a rosebud. That makes a lot of nasty smoke that's bad to breathe. If you're burning brush this spring you could add it to your burn pile but that's hard on the paint.
1951 3800 1-ton
In the DITY Gallery
Put it on the ground etc. Dump a bag of charcoal on it and light it off. When the charcoal is finished, so is the draft tube. Tap out the residue, wash it out and spray it with the paint of your choice.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
Thanks for the tip 👍😁👍🇺🇸👍
1962 C10 with a 235 6cyl -- all of the drive train seems to be original.
Some of this story is in the Side Lot
Some people like a new truck. I liked the old ones.
That looks cool.
Did you make S’Mores?
1951 3100
fattboyzz That's the way,brush pile works good too !!
Cornbread 😁👍🤣
As soon as I looked at the pic , I thought stovepipe from a stovebolt . Lol
