6 members (GRNHydra, 49nut, Wally / Montana, cmayna, Hotrod Lincoln, 1 invisible), 184 guests, and 1 robot.
Topics128,087
Posts1,055,980
Members48,430
#1496082 04/10/2023 7:05 PM
Replacing the yoke I noticed broken needle bearings in 1 bearing.
Should I look for the needles or the whole bearing?
Both bearings should be replaced. Whats the part # for those in a 1959 chevy truck?
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
7
7 Offline
Replace the complete universal joint, I don't think you can even buy the caps and needles, unless you have an old one that has the same dimensions.
I did have an old set. I used one of those.
Its ready now for the M-22.
thanks!
~ BD.
Would you guys know what "U" joint is right for my application?
1958 3100 1/2 ton. I have a slight vibration while driving.
There a few options at the local store and was not sure.
spicer 1310?
~ BD.
7
7 Offline
measure the cap diameter and distance from end of cap to opposite end of cap.
Thanks, yep Spicer 1310 . No more vibration. I should
have just replaced the "U" joint from the get go.
~ BD.
Just replaced all of my U-Joints from Rockauto. GMB 2100178 (210-0178). Fit great, and is a great price too!
https://www.rockauto.com/en/moreinfo.php?pk=5804154&jsn=3
CBall,
Correct me if I'm wrong, but isn't your truck a '48 3800 (1 Ton)???
U-joints for your truck aren't the same as for Guitplayer's '58 3100 (1/2 Ton).
Just don't want to confuse anybody on which parts fit his requirement.
Dan
~ Dan
1951 Chevy 3 window 3100
Thats right Dan! I can you guys for certain that the spicer 1310 is the right fit for a 58-59 3100 1/2 ton.
~ BD.
OMG! Apparently I did not get enough sleep last night as I read it as a '49. My apologies please disregard my earlier post
CBall,
If your OK with it, we can just take a small step back in time and make that bugger disappear. wink
No harm - No foul grin
OK by you???
Dan
~ Dan
This AC Delco is also the right fit for my 58-59 Apache 3100.
ACDelco Professional 45U0107 U-Joint
~ BD.
