0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2020 Posts: 1,961 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,961 | Replacing the yoke I noticed broken needle bearings in 1 bearing. Should I look for the needles or the whole bearing? Both bearings should be replaced. Whats the part # for those in a 1959 chevy truck?
~ BD. "You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
| | | | | Joined: Feb 2016 Posts: 1,989 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,989 | Replace the complete universal joint, I don't think you can even buy the caps and needles, unless you have an old one that has the same dimensions.
| | | | | Joined: Dec 2020 Posts: 1,961 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,961 | I did have an old set. I used one of those. Its ready now for the M-22. thanks!
| | | | | Joined: Dec 2020 Posts: 1,961 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,961 | Replace the complete universal joint, I don't think you can even buy the caps and needles, unless you have an old one that has the same dimensions. Would you guys know what "U" joint is right for my application? 1958 3100 1/2 ton. I have a slight vibration while driving. There a few options at the local store and was not sure. spicer 1310?
| | | | | Joined: Feb 2016 Posts: 1,989 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,989 | measure the cap diameter and distance from end of cap to opposite end of cap.
| | | | | Joined: Dec 2020 Posts: 1,961 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,961 | Thanks, yep Spicer 1310 . No more vibration. I should have just replaced the "U" joint from the get go.
| | | | | Joined: Sep 2009 Posts: 5,864 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,864 | CBall,
Correct me if I'm wrong, but isn't your truck a '48 3800 (1 Ton)???
U-joints for your truck aren't the same as for Guitplayer's '58 3100 (1/2 Ton).
Just don't want to confuse anybody on which parts fit his requirement.
Dan
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Dec 2020 Posts: 1,961 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,961 | Thats right Dan! I can you guys for certain that the spicer 1310 is the right fit for a 58-59 3100 1/2 ton.
| | | | | Joined: Mar 2023 Posts: 82 'Bolter | | 'Bolter Joined: Mar 2023 Posts: 82 | OMG! Apparently I did not get enough sleep last night as I read it as a '49. My apologies please disregard my earlier post
| | | | | Joined: Sep 2009 Posts: 5,864 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,864 | CBall, If your OK with it, we can just take a small step back in time and make that bugger disappear.  No harm - No foul  OK by you??? Dan
| | | | | Joined: Dec 2020 Posts: 1,961 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,961 | This AC Delco is also the right fit for my 58-59 Apache 3100. ACDelco Professional 45U0107 U-Joint
