1 members (Hotrod Lincoln),
41
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2022 Posts: 114 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 114 | At what safe rpm range can a 350 chevy truck run at on say a longe road trip? | | | | | Joined: Feb 2023 Posts: 374 'Bolter | | 'Bolter Joined: Feb 2023 Posts: 374 | I wouldn't be afraid of the 3,000 rpm range, + or - a little. Assuming everything is in good operating order. | | | | | Joined: Feb 2016 Posts: 1,982 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,982 | If you are talking about a Chevy 350 c.i. engine, it is considered a short stroke engine designed for medium to high RPM. My 1957 283 is governed at 4000 RPM, it was able to sustain that for hours and/or miles. The 265/283 is the grandaddy of the 350, same basic engine. A 350 that is in decent condition will have no issue with that engine speed.
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Most stock 350's don`t reach peak torque to about 3600 to 3800 RPM. In industrial applications they run 3000 + RPM for days at a time. When I used to have a boat, we very rarely cruised less than 3000 RPM. | | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | We routinely turned small block V8's into the high 7K range on the dirt tracks. Yours will get you into speeding ticket territory for thousands of miles, regardless of the gear ratio you choose, unless you're running some kind of rock crawler offroad machine. Jerry
| | | | | Joined: Jan 2022 Posts: 114 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 114 | I'd also forgot to mention a safe rpm with a relatively stock 235' engine on a long road trip, and Hotrod how did you keep from getting a speeding ticket going over that Grapevine with that there whale you told us about many moons ago? | | | | | Joined: Mar 2014 Posts: 4,480 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,480 | A stock 235? After owning and driving these engines for about 60 years, I would say something around 25~2600 rpm for a long road trip would be the most I would ever consider suggesting to you. If the engine has been rebuilt professionally to OEM standards, 3000 rpm would be okay, but you also have to weigh reasonability vs economy. The 235 at 3000 rpm certainly will not be in the "economy zone." And it will sound like you're abusing it at that speed. If the 235 has several thousand miles on it, bad things can happen if you push it too hard. It has been about 6 or 7 years but a member on one forum I belong to posted a picture of a piston rod sticking out the side of his 235 with the message being something like "it sounded like I was overworking it before it exploded." The 235 in stock condition is anything but a racing engine. It is nothing like the small block V8 in any way. Have you ever been in a truck that threw a rod? Here is the sequence of events: horrible noise followed by a seized engine with possible loss of control (depending on where you are and road conditions...curve, wet road, etc). Driver startled out of his/her wits. If it happens on the upstroke, the piston keeps going on up to the head. If the rod is thrown while the piston is coming down, it can go through the side of the block. In any event the engine is instantly seriously imbalanced and not something you can drive home. Often the engine can't be repaired.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
