Winter is Coming
A good Tech Tip WINTERIZING YOUR TRUCK including a link back to the Forums for additional tips.
I’m progressing on my 70 C10 and found this “shim” (for lack of better word) in a bag labelled front end “shuff”.
Any idea what this is/where it goes?
I have checked the “puzzle box” C20 parts truck and can’t find it on there either.
1970 Chevrolet C10 Grandpa's -- My first truck -- In progress to shiny Follow the build in the Project Journal 1950 Chevrolet 1-Ton Dually "Ole Red Girl" In the Stovebolt Gallery More pictures here 1951 GMC 9430 1 ton dually--Shiny! | 1972 Chevrolet C20- Rusty- the puzzle box lid for the C10 | 1962 AMC Rambler American- my wife's Parts trucks- 1951 GMC 9300 | 1951-GMC 9430 | 1951- Chevrolet 1300
That's an "F" shim. No idea where it might go, though. I've seen some that looked like a "Y" that are used to shim the sheet metal mounting points on a front clip. Maybe that one has the "handle" in a different position to make it possible to slip into place.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
Thanks fellas. Behind the inner fender seems logical. I will double check the c20 on the right side. Maybe it has one on that side. I think it is a cool looking shim. Bahaha!
