0 members (), 90 guests, and 2 robots.
Topics128,079
Posts1,056,310
Members48,442
Well.... I put on 31's and a new carb. did some burnouts and broke something. Imagine that! I'm not well versed in GM 4X4 from the '70. Not sure but the case looks divorced to me. The '74 crossmember was used and has a casting that seems to contain a shaft. I always assumed it was an open shaft. problem is under power the drivetrain seems fine. when it "relaxes" or coast it has a horrible bad sound. The throw out bearing made some noise once I put it back on the road after it sat 10. I don't think it's the problem. I'm assuming it's a chain drive case. It's behind a 4 speed granny gear trans.
Crusing in the Passing Lane
Picture of drivetrain would help.
Ed
scout4924,
As your conversation has to do with a truck converted to a later drivetrian, your post has been moved to the HiPo Shop for further conversation and discussion to help you with your problem.
Am sure fellow Bolters with some experience with running such a later 4X4 drive train will chime in soon with helpful tips and info.
Dan
~ Dan
1951 Chevy 3 window 3100
I am a bit confused. What is your question?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
