| | | Forums66 Topics128,188 Posts1,057,334 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 12 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 12 | I am wanting to check the site for information on the feasibility of fixing rust on a 57 Chevy pickup. the area in question is the interior of the cab above the visor. What is that area called? I don't even know what to put in the search tab. Thanks. | | | | | Joined: Jul 2000 Posts: 2,204 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,204 | Wow! Your first post in 12 years!
It probably would be helpful to post a picture of the area of concern.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: May 2015 Posts: 11,177 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,177 | Check This thread.There are a couple links that will help you out.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Got a 59 3100 in a couple days ago with same problem caused by mouse pee. Last one we done we had to hand form our own replacement panels but customer bought some with him so they are now available. IF, big IF, I remember I'll do a step by step pics.
Evan
| | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | Heat and humidity inside the cab during the day forms condensation on the underside of the roof skin at night as the night time temps cool the exterior sheet metal. This then drains to where gravity takes it, normally that header panel above the WS or down inside the doglegs of the A pillar (so check them too). | | | | | Joined: Oct 2009 Posts: 12 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 12 | Thanks fellas. Ill reorient myself on how to post pictures and do so. | | |
