1 members (NJC), 132 guests, and 2 robots.
Topics128,162
Posts1,056,941
Members48,458
I have installed 4 wheel disc brakes on the 1950 3100. I have 69 Chevy truck 12 bolt. I have added a dual master cylinder in the stock location.Do I need to install Residual Brake Pressure Check Valve ? I am sure this has been ask before.
Thanks Tom
3B Offline
Hy Stove bolt Tom 1, if your master cylinder is below the cab floor and therefor possibly below the height of your brake calipers, you should install 2 p.s.i. residual pressure valves in each brake circuit (front and rear, that is assuming that you have a dual master cylinder) hope that helps.
Thank you sir, that is what I was thinking but wanted to be sure.
