2 members (Still At It, wilbur53), 130 guests, and 3 robots.
Topics128,196
Posts1,057,387
Members48,471
Can anyone recommend a good rebuild kit and ring/pinion for the 1/2 ton rear end. It's the original that was in the suburban when it was purchased in 1974. It sat for 30 years, but I have done a ton of work to get the old girl on the road. It runs and drives, but I would like to go through all the running gear eventually.
It should be a standard 3.90 rear axle found in 2 wheel drive 1/2 ton trucks, if that helps any.
