3 members (55shaker, Wally / Montana, Steelonsteel), 143 guests, and 4 robots.
Topics128,201
Posts1,057,276
Members48,466
Can anyone recommend a good rebuild kit and ring/pinion for the 1/2 ton rear end. It's the original that was in the suburban when it was purchased in 1974. It sat for 30 years, but I have done a ton of work to get the old girl on the road. It runs and drives, but I would like to go through all the running gear eventually.
It should be a standard 3.90 rear axle found in 2 wheel drive 1/2 ton trucks, if that helps any.
