| | | Forums66 Topics128,075 Posts1,055,918 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2020 Posts: 4 Moderated | | Moderated Joined: Dec 2020 Posts: 4 | My head hurts. I have a 1949 Chevy 3600 with a 216 on a 6 volt system, known to some as "Wrecker" or "Texas Red". The current problem is that after a couple of stomps the starter drains the battery without ever getting the drive spinning properly. Sounds like Grrrr, grr, gr, g ... The dedicated 6 volt battery is kept charged on a tender. I've removed all the electrical (mouse eaten) with the exception of the Go/NoGo switch to the coil and from the coil to the distributor. Recently I pulled out the starter and replaced the brushes and switch and gave it a good cleaning. Replaced the starter pedal return spring with a NOS one. The only thing I can think of left to do is replace the battery cables with heavier 4/0 (0000). I have SAE 1 on there now. Could this be the solution to the problem? Rob | | | | | Joined: Oct 2021 Posts: 6,772 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,772 | 00 gauge cables are large enough.
You say the battery goes dead with just a push or two of the starter switch? I would first take your battery to Auto Zone and have them put a load tester on it. How old is it?
If it's perfect, then the starter probably needs to be rebuilt, not just the brushes.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Sep 2010 Posts: 2,307 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,307 | Check the ground wire from the starter to the frame and from the battery to the frame also. | | | | | Joined: Feb 2023 Posts: 375 'Bolter | | 'Bolter Joined: Feb 2023 Posts: 375 | Maybe the bushing at rear of starter is worn out. They seem to go first. It easy to replace once the starter is removed. | | |
